I am getting a strange error when I try to move containers to another project. I have three containers, all of them giving the same error when I try to move them in a stopped state to the other project:
Failed creating instance record: Unknown configuration key: volatile.apply_nvram
I have no idea what that means as these are containers that do not have this config key defined anywhere. Here is a config of one of the containers:
image.architecture: amd64
image.description: Alpine edge amd64 (20260302_13:00)
image.os: Alpine
image.release: edge
image.requirements.secureboot: 'false'
image.serial: '20260302_13:00'
image.type: squashfs
image.variant: default
volatile.base_image: 0d9ff68f8505bf3c0da75fbd6ed9f9d58e571ed105bcbdc8ef182b6c240a3245
volatile.cloud-init.instance-id: fc7729d7-6942-4d89-96cb-ed0253439823
volatile.eth0.hwaddr: 10:66:6a:1b:2c:a0
volatile.eth0.name: eth0
volatile.idmap.base: '0'
volatile.uuid: 4ebb4888-704d-48db-8634-5fbf940bacf2
volatile.uuid.generation: 4ebb4888-704d-48db-8634-5fbf940bacf2
devices: {}
- prod
description: ''
created_at: '2026-03-03T22:02:45.524594486Z'
status: Stopped
status_code: 102
last_used_at: '2026-03-04T11:15:53.678688843Z'
type: container
project: default
And here the two profiles that are applied:
description: Basis config
pool: default
security.secureboot: 'false'
project: default
description: Server Instances (VLAN 50)
nictype: bridged
parent: vmbr0
vlan: '50'
config: {}
project: default
looks like I’m experiencing a similar error when I’m trying to copy one of my containers.
╭─root at arch-laptop in /var/lib/incus/
╰─○ incus list -c nsum4Nt
| NAME | STATE | CPU USAGE | MEMORY USAGE | IPV4 | PROCESSES | TYPE |
| d13-cc | RUNNING | 1s | 96.65MiB | 10.218.57.76 (eth0) | 13 | CONTAINER |
| d13-oc | RUNNING | 7s | 669.73MiB | 10.218.57.212 (eth0) | 59 | CONTAINER |
| rk9-vm | STOPPED | | | | | VIRTUAL-MACHINE |
╰─○ incus copy d13-oc d13-oc-wc
Error: Failed creating instance record: Unknown configuration key: volatile.apply_nvram
╰─○ incus config show d13-oc
image.description: Debian trixie amd64 (20260205_05:24)
image.os: Debian
image.release: trixie
image.serial: "20260205_05:24"
image.variant: cloud
volatile.base_image: 2a5984a45bb5cc348488481b090a9eda49bdcc4d1668bedc49ee06f5e3f08ab2
volatile.cloud-init.instance-id: 5ab5cf65-f417-409d-8742-fc23720dff61
volatile.eth0.host_name: vethafdfd885
volatile.eth0.hwaddr: 10:66:6a:f4:4a:9e
volatile.idmap.base: "0"
volatile.uuid: cf53f7ff-82e5-4127-9223-0af3d080368f
volatile.uuid.generation: cf53f7ff-82e5-4127-9223-0af3d080368f
devices: {}
Update:
After a config in default profile got unset, the issue is resolved.
╰─○ incus profile show default
security.secureboot: "false"
network: br-incus0
pool: default
- /1.0/instances/arch-proxy
- /1.0/instances/rk9-vm
- /1.0/instances/d13-cc
- /1.0/instances/d13-oc
project: default
╰─○ incus profile unset default security.secureboot
config: {}
network: br-incus0
pool: default
- /1.0/instances/d13-oc-wc
project: default
Yes, that also works for my issue. So the workflow would be to remove security.secureboot, copy or move the container(s), and then reactivate the secureboot setting.
To me that still looks like a bug. Should we report it somewhere on a bug tracker?
Yep, that might be a bug. A vm related config (if it really is), is not supposed to affect the copy of containers IMHO.
I did a little reseach when the issue happened, but there was nothing more from google except this post. I believed there must be something different in the config that could bring this weird behavior which doesn’t exist on my several other hosts - so it was either in container conf or the profile - and bingo.
