hi,
I am trying to install docker in lxc container with security.privileged and security.nesting options as true. it is showing error of
service error message
docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: failed (Result: start-limit-hit) since Mon 2019-01-28 10:10:38 UTC; 33s ago
Docs: https://docs.docker.com
Process: 681 ExecStart=/usr/bin/dockerd -H fd:// (code=exited, status=1/FAILURE)
Main PID: 681 (code=exited, status=1/FAILURE)
Jan 28 10:10:38 kmaster systemd[1]: docker.service: Failed with result ‘exit-code’.
Jan 28 10:10:38 kmaster systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Jan 28 10:10:38 kmaster systemd[1]: Stopped Docker Application Container Engine.
Jan 28 10:10:38 kmaster systemd[1]: docker.service: Start request repeated too quickly.
Jan 28 10:10:38 kmaster systemd[1]: Failed to start Docker Application Container Engine.
Jan 28 10:10:38 kmaster systemd[1]: docker.service: Unit entered failed state.
Jan 28 10:10:38 kmaster systemd[1]: docker.service: Failed with result ‘start-limit-hit’.
Jan 28 10:11:03 kmaster systemd[1]: docker.service: Start request repeated too quickly.
Jan 28 10:11:03 kmaster systemd[1]: Failed to start Docker Application Container Engine.
Jan 28 10:11:03 kmaster systemd[1]: docker.service: Failed with result ‘start-limit-hit’.
Is there any way to install docker in lxc container with zfs storage
