I am trying to install the docker container GitHub - jaikumarm/docker-iqfeed: Dockerized IQFeed client with X11VNC for remote viewing inside LXD.
When installing wine inside the docker container, I get the following error:
Step 14/24 : RUN dpkg --add-architecture i386 && apt-get update && apt-get upgrade -yq && apt-get install -yq --no-install-recommends software-properties-common apt-utils supervisor xvfb wget tar gpg-agent bbe netcat-openbsd net-tools && wget -O - https://dl.winehq.org/wine-builds/winehq.key | apt-key add - && echo ‘deb Index of /wine-builds/ubuntu focal main’ |tee /etc/apt/sources.list.d/winehq.list && apt-get update && apt-get install -yq --no-install-recommends winehq-stable winbind winetricks cabextract && mkdir /opt/wine-stable/share/wine/mono && wget -O - https://dl.winehq.org/wine/wine-mono/4.9.4/wine-mono-bin-4.9.4.tar.gz |tar -xzv -C /opt/wine-stable/share/wine/mono && mkdir /opt/wine-stable/share/wine/gecko && wget -O /opt/wine-stable/share/wine/gecko/wine-gecko-2.47.1-x86.msi https://dl.winehq.org/wine/wine-gecko/2.47.1/wine-gecko-2.47.1-x86.msi && wget -O /opt/wine-stable/share/wine/gecko/wine-gecko-2.47.1-x86_64.msi https://dl.winehq.org/wine/wine-gecko/2.47.1/wine-gecko-2.47.1-x86_64.msi && apt-get install -yq --no-install-recommends git python3 python3-setuptools python3-numpy python3-pip python3-tz python3-psycopg2 python3-dateutil python3-sqlalchemy python3-pandas && apt-get autoremove -y --purge && apt-get clean -y && rm -rf /var/lib/apt/lists/* /tmp/* /var/tmp/*
—> Running in 35395dfd3095
OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "rootfs_linux.go:58: mounting \"proc\" to rootfs \"/var/snap/docker/common/var-lib-docker/overlay2/47cff7ae2ce809720ff63ceaf7d8ab69a898fcd6cd23ae25bc7ca906d186d8c4/merged\" at \"/proc\" caused \"permission denied\""”: unknown
Does anyone see a fix for this? (outside LXD it all works fine)
