I am setting up an OVN for cluster latest Incus version 6.0. I have 4 nodes as follows:
Node 1:
inet6 ::1/128 scope host noprefixroute
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master br0 state UP group default qlen 1000
link/ether 2c:cf:67:0a:f0:f3 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 2c:cf:67:0a:f0:f4 brd ff:ff:ff:ff:ff:ff
4: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether a2:dd:cd:a2:96:00 brd ff:ff:ff:ff:ff:ff
5: br-int: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 66:62:2a:d7:75:15 brd ff:ff:ff:ff:ff:ff
6: genev_sys_6081: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 65000 qdisc noqueue master ovs-system state UNKNOWN group default qlen 1000
link/ether 2e:97:f3:f7:8e:e7 brd ff:ff:ff:ff:ff:ff
inet6 fe80::9c7b:70ff:fec2:87a3/64 scope link
7: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether ee:f7:fd:27:dd:01 brd ff:ff:ff:ff:ff:ff
inet 10.0.1.179/24 brd 10.0.1.255 scope global br0
inet6 fe80::ecf7:fdff:fe27:dd01/64 scope link
Node 2: 10.0.1.176
Node 3: 10.0.1.178
Node 4: 10.0.1.177
I get an error when creating UPLINK network on Node 1 as shown below:
incus network create UPLINK --type=physical parent=br0 --target=rpicluster01
Network UPLINK pending on member rpicluster01
root@rpicluster01:~# incus network create UPLINK --type=physical parent=br0 --target=rpicluster02
Network UPLINK pending on member rpicluster02
root@rpicluster01:~# incus network create UPLINK --type=physical parent=br0 --target=rpicluster03
Network UPLINK pending on member rpicluster03
root@rpicluster01:~# incus network create UPLINK --type=physical parent=br0 --target=rpicluster04
Network UPLINK pending on member rpicluster04
Error: failed to notify peer 10.0.1.176:8443: Parent interface "br0" not found
Here’s the configuration I put into /etc/netplan
config file:
network:
version: 2
renderer: networkd
ethernets:
dhcp4: no
bridges:
br0:
interfaces: [eth0]
addresses: [10.0.1.179/24]
routes:
- to: default
via: 10.0.1.1
nameservers:
addresses:
- 1.1.1.1
- 1.0.0.1
parameters:
stp: true
forward-delay: 4
dhcp4: no
Output from incus network ls
is as follows:
root@rpicluster01:/etc/netplan# incus network ls
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| UPLINK | physical | YES | | | | 0 | ERRORED |
| br0 | bridge | NO | | | | 0 | |
| eth0 | physical | NO | | | | 0 | |
| wlan0 | physical | NO | | | | 0 | |
What am I doing wrong?
