Error with docker inside lxc container
Hello folks!
I’m facing with a weird problem with my server, I’m using LXC/LXD for a while with a good results overall, but since yesterday (no updates were installed) I’m having a lot of troubles when triying to create or start a docker instance.
If I run (inside a lxc container) this
$ docker run hello-world
docker: Error response from daemon: oci runtime error: could not create session key: disk quota exceeded.
this is the current version of docker (insude LXC container)
Client:
Version: 1.12.3
API version: 1.24
Go version: go1.6.2
Git commit: 6b644ec
Built: Mon, 19 Dec 2016 09:20:48 +1300
OS/Arch: linux/amd64
Server:
Version: 1.12.3
API version: 1.24
Go version: go1.6.2
Git commit: 6b644ec
this is the version of LXC
root@xxxx:~# lxc version
2.0.9
I’ve checked almost everything (like free space, inodes, etc and everything looks fine) I have ext4 as filesystem (so no disk quota at all)
$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 8229243 499 8228744 1% /dev
tmpfs 8234072 1970 8232102 1% /run
/dev/md1 27992064 6655709 21336355 24% /
tmpfs 8234072 1 8234071 1% /dev/shm
tmpfs 8234072 4 8234068 1% /run/lock
tmpfs 8234072 16 8234056 1% /sys/fs/cgroup
/dev/md2 1281120 13 1281107 1% /home
tmpfs 8234072 4 8234068 1% /run/user/0
Any thoughts?
Outside LXC container docker works as expected (tested using hello-world docker)
If you need further information please let me know.
Thank you.
Kinda sounds like Docker may be attempting to use the kernel keyring?
That’d certainly be a new behavior from them…
Unfortunately you version of LXD doesn’t support syscall blacklisting so it’s not particularly easy to test/workaround in your case…
Where did you get that version of Docker?
Hello!
That docker version is from docker.io repo
I've found the solution; increasing /proc/sys/kernel/keys/maxkeys from 200 to a higher value (50000) fixed the problem, I think that it was because I have almost 30 lxc containers running and all of them are unprivileged.
Many thanks for your help!
Ah, that’s good to know.
Can confirm as of Dec 2019 that this works - do sudo echo "5000" > /proc/sys/kernel/keys/maxkeys on your LXD host.
The command should rather be something like
echo 5000 | sudo tee /proc/sys/kernel/keys/maxkeys
still prolem as of 2022 , lxd should come with a profile setup for dockers.
This is covered in Production setup - LXD documentation
Thanks , here i made a copy-pastable version for new comers.
fs.aio-max-nr=524288
fs.inotify.max_queued_events=1048576
fs.inotify.max_user_instances=1048576
fs.inotify.max_user_watches=1048576
kernel.dmesg_restrict=1
kernel.keys.maxbytes=2000000
kernel.keys.maxkeys=20000
net.ipv4.neigh.default.gc_thresh3=8192
net.ipv6.neigh.default.gc_thresh3=8192
vm.max_map_count=262144
Another problem is Ulimit :
add to /etc/security/limits.conf
    * soft core unlimited
    * hard core unlimited
    * soft data unlimited
    * hard data unlimited
    * soft fsize unlimited
    * hard fsize unlimited
    * soft memlock unlimited
    * hard memlock unlimited
    * soft nofile 1048576
    * hard nofile 1048576
    * soft rss unlimited
    * hard rss unlimited
    * soft stack unlimited
    * hard stack unlimited
    * soft cpu unlimited
    * hard cpu unlimited
    * soft nproc unlimited
    * hard nproc unlimited
    * soft as unlimited
    * hard as unlimited
    * soft maxlogins unlimited
    * hard maxlogins unlimited
    * soft maxsyslogins unlimited
    * hard maxsyslogins unlimited
    * soft locks unlimited
    * hard locks unlimited
    * soft sigpending unlimited
    * hard sigpending unlimited
    * soft msgqueue unlimited
    * hard msgqueue unlimited
This is now available at Production setup - LXD documentation
