I have a VM in the default project, which runs fine. If I stop it and move it to another project called “Proxmox”, the VM no longer starts. It shows this error message:
Unable to locate matching firmware: [{Code:/nix/store/cxm4xcn3cgq9np2qs76ls6a4dh2rh6vq-incus-ovmf/OVMF_CODE.4MB.fd Vars:/nix/store/cxm4xcn3cgq9np2qs76ls6a4dh2rh6vq-incus-ovmf/OVMF_VARS.4MB.ms.fd} {Code:/nix/store/cxm4xcn3cgq9np2qs76ls6a4dh2rh6vq-incus-ovmf/OVMF_CODE.fd Vars:/nix/store/cxm4xcn3cgq9np2qs76ls6a4dh2rh6vq-incus-ovmf/OVMF_VARS.ms.fd}]
The strange thing is that the firmwares are available in the directory:
$ ls /nix/store/cxm4xcn3cgq9np2qs76ls6a4dh2rh6vq-incus-ovmf
OVMF_CODE.4MB.fd OVMF_CODE.fd OVMF_VARS.4MB.fd OVMF_VARS.4MB.ms.fd OVMF_VARS.fd OVMF_VARS.ms.fd seabios.bin
Now, If I try to move the VM back to default, I get the following error:
Error deleting storage volume: Failed to remove '/var/lib/incus/storage-pools/default/virtual-machines/Proxmox_Proxmox3': remove /var/lib/incus/storage-pools/default/virtual-machines/Proxmox_Proxmox3: device or resource busy
After that, the VM is visible in both projects, “default” and “Proxmox”, but only is missing the block device in “Proxmox”. I can delete the instance in the “Proxmox” project. The version in the “default” project runs fine again.
I can repeat the whole thing getting exactly the same result.
$ incus version
Client version: 6.21
Server version: 6.21
$ incus config show Proxmox3 --project default
limits.cpu: “4”
limits.memory: 6GiB
volatile.cloud-init.instance-id: f5c27a6b-6c5c-4efe-ad75-3fac7d353513
volatile.eth0.host_name: tapf91ac964
volatile.eth0.hwaddr: 10:66:6a:d5:11:d4
volatile.last_state.ready: “false”
volatile.uuid: 6df2d229-c8ed-49c5-b8a7-163052ad9274
volatile.uuid.generation: 6df2d229-c8ed-49c5-b8a7-163052ad9274
volatile.vm.definition: pc-q35-10.1
volatile.vm.rtc_adjustment: “0”
volatile.vm.rtc_offset: “-1”
volatile.vsock_id: “2055157134”
nictype: bridged
parent: vmbr0
vlan: “10”
vlan.tagged: 2-4094
pool: default
sda:
source: /dev/sda
default
description: “”
Any idea, what is the problem?
