/etc/netplan/50-cloud-init.yaml spontaneously created when container is stopped, renamed, and then started
Bare metal context: Ubuntu 22.02.2 running latest/stable snap lxd.
The default profile networking is set to NIC-bound br0 bridge with no local bridge enabled.
lxc init ubuntu:22.04 digital-archives
After spinning up this container, I created a /etc/netplan/10-lxc.yaml file configured with a static IP address and moved 50-cloud-init.yaml to 50-cloud-init.yaml-ORIG so it wouldn’t execute and ran
netplan apply
However, see below:
archives@www2:~$ lxc list
|       NAME       |  STATE  |        IPV4         | IPV6 |   TYPE    | SNAPSHOTS |
| digital-archives | RUNNING | 172.18.90.42 (eth0) |      | CONTAINER | 0         |
archives@www2:~$ lxc stop digital-archives
| digital-archives | STOPPED |      |      | CONTAINER | 0         |
archives@www2:~$ lxc move digital-archives digitalarchives
| digitalarchives | STOPPED |      |      | CONTAINER | 0         |
archives@www2:~$ lxc start digitalarchives
| digitalarchives | RUNNING | 172.18.90.42 (eth0)  |      | CONTAINER | 0         |
|                 |         | 172.18.90.227 (eth0) |      |           |           |
On further examination, the 50-cloud-init.yaml netplan was magically recreated:
root@digital-archives:~# ls /etc/netplan
10-lxc.yaml  50-cloud-init.yaml  50-cloud-init.yaml-ORIG
Any idea why this happened?
I changed the name of the container back to the original name, removed /etc/netplan/50-cloud-init.yaml and now the behavior doesn’t repeat:
archives@www2:~$ lxc start digital-archives
Just a little bit of additional testing shows that the creation of /etc/netplan/50-cloud-init.yaml is triggered by changing the name of the container. Repeating my previous steps:
I’m going to call this a bug rather than a feature. :slightly_smiling_face:
The LXD team do not produce the images from ubuntu: remote, so ubuntu:22.04 is one of the official Ubuntu images.
Does it occur using the images:ubuntu/22.04 or images:ubuntu/22.04/cloud images?
I’ve only ever used the images:ubuntu/22.04 images, so it’s happening with those images. This isn’t a huge issue since the names of containers rarely change, I suspect, but I don’t understand how this would be happening, which is what bothers me.
I’ve confirmed this behaviour, and its happening because LXD regenerates the volatile.cloud-init.instance-id config key on rename. This then triggers cloud-init to regenerate its config on next start.
See https://linuxcontainers.org/lxd/docs/master/reference/instance_options/#volatile-internal-data
And https://github.com/lxc/lxd/issues/9814
