Even with root user Im receiving ‘Operation not permitted’ when try creating gluster volume between Ubuntu 14.04 LXC containers.
Even adding the ppa:gluster/glusterfs-4.1 the update failed to get the last version of GlusterFs as can see on code below.
Need test the solution locally before install it on prodution and even locally i cant install.
Just come here now after all this time because wanted try hard before bother you again with it, thanks for the help.
Im trying solve the problem since your last comment without sucess, the current status is the following:
xfce4-terminal -T LocalTerm
exit
At LocalTerm:
PS1='[\u@\h]-[\D{%T}]-[\W] => '
lxc profile copy default default-bkp
lxc profile set default raw.lxc lxc.apparmor.profile=unconfined
clear
lxc stop ubt1404X64C001
lxc stop ubt1404X64C002
lxc delete ubt1404X64C001
lxc delete ubt1404X64C002
lxc launch ubuntu:14.04 ubt1404X64C001
lxc launch ubuntu:14.04 ubt1404X64C002
clear
sleep 10
lxc list --format csv
lxc config get ubt1404X64C001 security.privileged
lxc config set ubt1404X64C001 security.privileged true
lxc config get ubt1404X64C002 security.privileged
lxc config set ubt1404X64C002 security.privileged true
lxc restart ubt1404X64C001
lxc restart ubt1404X64C002
xfce4-terminal -T ubt1404X64C001Term -e "bash -c 'lxc exec ubt1404X64C001 -- /bin/bash; exec bash; exit 0;'"
xfce4-terminal -T ubt1404X64C002Term -e "bash -c 'lxc exec ubt1404X64C002 -- /bin/bash; exec bash; exit 0;'"
At ubt1404X64C001Term and ubt1404X64C002Term:
echo '' >> /etc/hosts
apt-get update
apt-get upgrade
apt-get dist-upgrade
apt-get autoremove
apt-get install netcat net-tools
lsb_release -a
	No LSB modules are available.
	Distributor ID:	Ubuntu
	Description:	Ubuntu 14.04.5 LTS
	Release:	14.04
	Codename:	trusty
uname -a
	Linux ubt1404X64C002 4.15.0-36-generic #39-Ubuntu SMP Mon Sep 24 16:19:09 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
cat /etc/fstab
	LABEL=cloudimg-rootfs	/	 ext4	defaults	0 0
apt-get install attr fuse libaio1 liburcu-dev libxml2 python2.7 python-pip rpcbind
echo '' > ~/testAttr
setfattr -n user.name -v "UserNameValue" ~/testAttr
setfattr -n trusted.glusterfs.test -v "working" ~/testAttr
getfattr -d -m - ~/testAttr
	trusted.glusterfs.test="working"
	user.name="UserNameValue"
add-apt-repository ppa:gluster/glusterfs-4.1
apt-get update
	W: Failed to fetch
	http://ppa.launchpad.net/gluster/glusterfs-4.1/ubuntu/dists
	/trusty/main/binary-amd64/Packages  404  Not Found
	E: Some index files failed to download. They have been ignored, or old ones used instead.
	but available to: artful,bionic,cosmic,devel and xenial
apt-get install glusterfs-server glusterfs-client open-iscsi watchdog
glusterfs --version | grep built
	glusterfs 3.4.2 built on Jan 14 2014 18:05:35
	Not installed 4.1 version because apt-get update failed with error above to trusty version
At ubt1404X64C002Term:
ifconfig eth0 | grep 'inet '
	20.30.40.50
echo '10.20.30.40 ubt1404X64C001' >> /etc/hosts
cat /etc/hostname
ping ubt1404X64C001
iptables -I INPUT -p all -s ubt1404X64C001 -j ACCEPT
At ubt1404X64C001Term:
	10.20.30.40
echo '20.30.40.50 ubt1404X64C002' >> /etc/hosts
cat /etc/hostname
ping ubt1404X64C002
iptables -I INPUT -p all -s ubt1404X64C002 -j ACCEPT
mkdir -p /root/tomirrorwith/glusterfs
cd /root/tomirrorwith/glusterfs
gluster peer probe ubt1404X64C002
	peer probe: success
gluster peer status
	Hostname: ubt1404X64C002
	Port: 24007
	State: Peer in Cluster (Connected)
gluster volume create gv0 replica 2 ubt1404X64C001:/root/tomirrorwith/glusterfs ubt1404X64C002:/root/tomirrorwith/glusterfs force
	volume create: gv0: failed
	/var/log/glusterfs/cli.log at ubt1404X64C001
		W [rpc-transport.c:175:rpc_transport_load] 0-rpc-transport: missing 'option transport-type'. defaulting to "socket"
		I [socket.c:3480:socket_init] 0-glusterfs: SSL support is NOT enabled
		I [socket.c:3495:socket_init] 0-glusterfs: using system polling thread
		I [cli-cmd-volume.c:392:cli_cmd_volume_create_cbk] 0-cli: Replicate cluster type found. Checking brick order.
		I [cli-cmd-volume.c:304:cli_cmd_check_brick_order] 0-cli: Brick order okay
		I [cli-rpc-ops.c:805:gf_cli_create_volume_cbk] 0-cli: Received resp to create volume
		I [input.c:36:cli_batch] 0-: Exiting with: -1
	/var/log/glusterfs/etc-glusterfs-glusterd.vol.log at ubt1404X64C002
		E [glusterd-op-sm.c:3719:glusterd_op_ac_stage_op] 0-management: Stage failed on operation 'Volume Create', Status : -1
TRY FIX At C001TermUbt1404X64:
    cd /sys/module/fuse/parameters/
    echo Y > userns_mounts
        ERROR:
            bash: userns_mounts: Permission denied
