I can’t figure out how to resize an LXC container filesystem. I’ve already overridden the default block storage device size, but I can’t “see” the block storage device inside the container.
# zfs get all default/containers/mycontainer
default/containers/mycontainer used 12.7G
default/containers/mycontainer referenced 13.0G
default/containers/mycontainer quota 30G
How do I get the filesystem on the ZFS device to “fill” the 30GB of space?
I tried using cfdisk inside the container, and it doesn’t “see” the filesystem. lsblk doesn’t show the filesystem.
I already set autoexpand on, for the default ZFS pool, so that shouldn’t be an issue. I’m just trying to resize this one container disk.
Yes, I already know how to resize the block device. However, I can’t figure out how to expand the filesystem inside the container, after resizing the block device. Any thoughts?
I figured it out. Finally found another thread with a similar issue.
It’s not clear from any documentation, but you have to run the truncate command to arbitrarily increase the zpool image size. Then you have to stop and restart LXD, so it “sees” the new ZFS pool size.
My container filesystem appears larger now, inside the container.
