Is there a way to export a container’s configuration, and then recreate it on another server from this file?
lxc config show NAME > out.yaml
lxc launch the-image NEW-NAME < out.yaml
As you can see, you still need to specify the image you want to create it from.
The rest of the config will be loaded from out.yaml
Amazing!
Thanks so much!
