➜ incus storage volume export default talend-open-studio talend-volume.tar.gz
Error: Failed to create storage volume backup: Storage pool volume not found
So, I am probalby using the wrong syntax… any hint is welcome.
there is something I missed then…
Doc on backup says
Important
If your Incus server uses any external storage (for example, LVM volume groups, ZFS zpools, or any other resource that isn’t directly self-contained to Incus), you must back this up separately.
Ah yeah, no idea what that link is doing there, it certainly should be there.
There are no instructions on how to backup your specific storage as that widely varies based on what it is and what kind of strategy you want to use for your backups.
In the case of a ZFS pool, you’d most likely be making a backup of /var/lib/incus combined with some kind of send/receive based backup of your zpool itself.
You’re correct the tarball will allow for restoring the instance elsewhere, though not that it doesn’t include any custom volumes that may be attached. You’ll also need to separately make sure that all needed profiles, networks, … exist prior to importing the backup.
