Hi there!
First of all I want to congratulate the team behind incusOS. I can’t belive it’s not more popular!
Second sorry for the LONG post
A bit of background:
I have been using incus (and lxc and lxd) in one way or another for a long time. I started with ubuntu which I keep updated but keep in a LTS release for very long before wanting to change for the next. This led to the use of lxd back then: I could have containers with newer version of the software while the base kept constant. Last year I jump ship to nixos. I though I would be wise to have an immutable system as a base and all the incus containers needed. I even started using cloud-init to create images I could then reuse (I use containers for “crash” isolation which ran podmans containers). I could rebuild the image from time to time, rebase the containers, and update the podman containers but taking also care of nixos proved to be a burden
Then incusOS came into consideration. I was bit hesitant at first but I finally managed to install it and reuse the same incus containers I had in the previous iteration of the server. I was immediatly so impressed with it I brought home a family server running proxmox which I “sometimes” updated and move it to incusOS. I could even reuse the same images I built for my system!
However, they way I see it incusOS is a very “opinated” OS. It’s not a critic, is just that I’m missing some tools from my previous OS (ubuntu, nixos) but mainly I’m missing the rationale. And I’m a little bit lost.
But I’m here for the long run, and I’m here to learn.
So the two main issues I’ve been having are: tailscale and mdadm+lvm (and smartctl)
Tailscale:
My network topology is for location #1:
- router1: 10.10.0.0/24
- server1: 10.10.0.10/32 with
- incusbr0: 10.10.10.0/24 without nat
and similar for #2:
- router2: 10.20.0.0/24
- server2: 10.20.0.10/32 with
- incusbr0: 10.20.10.0/24 without nat
I have tailscale installed in both routers (running openwrt) but I wanted to setup tailscale also in the server so it could use the server CPU when transfering between incusOS host servers (in different localtion) but also between incuOS containers.
I tried using the integrated tailscaled incusOS has but apparently if I add network 10.10.10.0/24 it would route everything through tailscale even when I’m local (10.10.0.0/24) because it adds a route with very high preference which cannot be overridden in incusOS
With this in mind
- I left incusOS tailscaled enabled but without any routes (not accepting any either)
- I create a sidecar container with tailscaled in it which I could control better
- I added the routing to the openwrt router
- I added dhcp option 121
It works but I don’t know if this is the correct way of doing it. Should I “ask” for a way to control the routing table in incusOS or was it deliberately designed this way? If so, is the sidecar container the correct way of doing this?
mdadm+lvm:
Due to “historical” reason I have a large (7x10TB raid6) mdadm+lvm array. I’m thinking about moving it to zfs (through the means of a cloud provider maybe?) but for the time being it is what it is.
If I understand correctly incusOS is primarily zfs (for local) so mdadm and lvm are not supported. Thus I created an incus VM (so it could have its own kernel for NFS) passthrough the drives to the container, and inside brought up mdadm array and lvm so I could share it with NFS. Then in each container I added a NFS (fuse) mount. Not as clean as “incus config edit” but it works.
I know this problem will probably go away if I decide to move to zfs raidz2 but for now. Is it the correct way of doing it?
smartclt:
Which brings as to the last question. If I want to run smartctl on the drives is passing the to a privileged container (that I would then immediatly stop) to run smarctl the correct way of doing things?
So in summary: there is no turning back to any other OS, but I sometimes feel a little bit lost and I don’t know if the things I’m doing to circumvent some of my problems are solutions or just hacks I should avoid.
Regards!
