Not sure if this is part of a larger problem yet, still doing some monitoring. But I have been getting failures when migrating containers over to another LXD host. Both of the VM hosts are on the same VLAN (vlan99) and the LXD hosts and containers are running on the same VLAN (vlan50).
I am running:
LXD 5.0.2 on both source and target, with small ZFS pools (64GB)
Running on Ubuntu 22.04 LTS on VM (16G RAM, 4cores)
VMs running on XCP-ng 8.2 VM hosts
Connected to storage backend: TrueNAS scale 22.12 (ZFS)
Here are some of the errors from target and source:
Error on target (LXD1)
Error: Failed instance creation: Error transferring instance data: Failed creating instance on target: Problem with zfs receive: ([exit status 1 read tcp 192.168.50.10:36360->192.168.50.11:8443: read: connection reset by peer]) cannot receive new filesystem stream: incomplete stream
lxc monitor on source (LXD2)
metadata:
context:
args: ‘&{IndexHeaderVersion:1 Name:zcs Snapshots:[] MigrationType:{FSType:ZFS
Features:[migration_header compress]} TrackProgress:true MultiSync:false FinalSync:false
Data: ContentType: AllowInconsistent:false Refresh:false Info:0xc000406398
VolumeOnly:false}’
instance: zcs
project: default
response: ‘{StatusCode:200 Error: Refresh:0xc002215663}’
version: “1”
level: info
message: Received migration index header response
timestamp: “2023-03-08T19:27:04.748580901-05:00”
type: logging
Note: This container is around 5Gb.
dmesg on target, this seems to crop up during the migration tasks:
[ 8822.769928] INFO: task receive_writer:14300 blocked for more than 120 seconds.
[ 8822.777322] Tainted: P O 5.15.0-67-generic #74-Ubuntu
[ 8822.785443] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 8822.794893] task:receive_writer state:D stack: 0 pid:14300 ppid: 2 flags:0x00004000
error on target when deleting a damaged container:
Error: Error deleting storage volume: Failed to run: zfs destroy -r default/containers/zcs: exit status 1 (cannot destroy ‘default/containers/zcs’: dataset is busy)
Now when I run lxc export on the target and imported the tar files, everything went fine. I saw this suggested by Tom in another post, so this went fine. No errors at all. I am not logging any disk errors so far, and everything runs fine otherwise. It’s only when I migrate a few containers over 4GB I get the error. Smaller containers migrate fine.
If anyone has seen this, or if this is a clue of a larger problem, I am just trying to rule out any hardware issues. I normally only move them around when doing maintenance on one of the VM hosts they all run on. All containers run fine 24/7 and I just started seeing this, so thought I would share.
Thank you
