I got a power outage which damaged the motherboard and raid controller of my server. Both are replaced now but I got filesystem issues now which prevents me from starting LXD.
EROR[09-02|13:52:08] Failed to start the daemon: Failed initializing storage pool “default”: Failed to mount “/dev/loop10” on “/var/snap/lxd/common/lxd/storage-pools/default” using “btrfs”: input/output error
I did an btrfs check and repair:
user@lxd:~$ sudo btrfs check --force --readonly --progress /dev/loop10
Opening filesystem to check…
parent transid verify failed on 680919613440 wanted 1279753 found 1279731
Ignoring transid failure
Checking filesystem on /dev/loop10
UUID: 2e657720-4b74-4d85-8aa8-82e0d397fd2d
[1/7] checking root items (0:01:20 elapsed, 38005611 items checked)
[2/7] checking extents (0:06:18 elapsed, 2379598 items checked)
[3/7] checking free space cache (0:00:14 elapsed, 2981 items checked)
root 34451 inode 72602 errors 100, file extent discount elapsed, 761082 items checked)
Found file extent holes:
start: 32552779776, len: 720896
start: 32560250880, len: 2293760
start: 32592232448, len: 65536
start: 32598851584, len: 65536
start: 32600621056, len: 196608
start: 32606650368, len: 196608
start: 32609796096, len: 131072
start: 32622182400, len: 5308416
start: 32627687424, len: 4390912
start: 32649445376, len: 131072
start: 32650493952, len: 65536
[4/7] checking fs roots (0:16:45 elapsed, 1935698 items checked)
ERROR: errors found in fs roots
found 2882307887865 bytes used, error(s) found
total csum bytes: 2757097344
total tree bytes: 38886555648
total fs tree bytes: 31900598272
total extent tree bytes: 3243638784
btree space waste bytes: 7146346875
file data blocks allocated: 71490025865216
referenced 4766790057984
user@lxd:~$ sudo btrfs check --force --readonly --progress --clear-space-cache v1 /dev/loop10
[sudo] password for user:
Free space cache cleared
user@lxd:~$ sudo btrfs check --force --repair --progress /dev/loop10
enabling repair mode
parent transid verify failed on 680919613440 wanted 1284109 found 1279731
repair mode will force to clear out log tree, are you sure? [y/N]: y
[1/7] checking root items (0:00:08 elapsed, 38003965 items checked)
Fixed 0 roots.
No device size related problem found (0:03:34 elapsed, 2379555 items checked)
[2/7] checking extents (0:03:35 elapsed, 2379555 items checked)
[3/7] checking free space cache (0:00:00 elapsed, 4356 items checked)
Fixed discount file extents for inode: 72602 in root: 34451psed, 761411 items checked)
warning line 3805 roots (0:21:59 elapsed, 2694819 items checked)
[4/7] checking fs roots (0:21:59 elapsed, 2697111 items checked)
[5/7] checking csums (without verifying data) (0:00:55 elapsed, 8717591 items checked)
[6/7] checking root refs (0:00:00 elapsed, 6242 items checked)
Recowing metadata block 680919613440
ERROR: fails to fix transid errors
[7/7] checking quota groups skipped (not enabled on this FS)
found 2881524105985 bytes used, error(s) found
total tree bytes: 38885851136
total extent tree bytes: 3243753472
btree space waste bytes: 7146550540
file data blocks allocated: 71489245200384
referenced 4766009393152
extent buffer leak: start 680919613440 len 16384
Then I tried starting the service again and got other errors:
Error: Failed to start dqlite server: raft_start(): io: closed segment 0000000000039600-0000000000039684 is past last snapshot snapshot-1-38912-2073756252
I renamed the file 0000000000039600-0000000000039684 then I got the error:
Error: Failed to start dqlite server: raft_start(): io: load closed segment 0000000000039600-0000000000039732: entries batch 28 starting at byte 268680: entries count in preamble is zero
so I also renamed 0000000000039600-0000000000039732:
root@lxd:/var/snap/lxd/common/lxd/database/global/
1532 -rw------- 1 root root 1568768 Sep 2 15:00 0000000000039600-0000000000039684.moved
1532 -rw------- 1 root root 1564968 Sep 2 15:00 0000000000039600-0000000000039732.moved
now I get:
Error: Failed initializing storage pool “default”: Failed to mount “/dev/loop10” on “/var/snap/lxd/common/lxd/storage-pools/default” using “btrfs”: invalid argument
I checked the storage image file:
sudo btrfs check /var/snap/lxd/common/lxd/disks/default.img
parent transid verify failed on 369479548928 wanted 1279751 found 1284111
ERROR: child eb corrupted: parent bytenr=184647680 item=55 parent level=1 child level=1
ERROR: failed to read block groups: Input/output error
ERROR: cannot open file system
Now I am stuck
Any help is appreciated
