In a nested container, I’m getting lxd init --auto --storage-backend btrfs which is somewhat expected given that the default is to use a loop device and those aren’t allowed in containers.
The interactive lxd init has additional logic for this particular case:
root@c1:~# lxd init
Do you want to configure a new storage pool (yes/no) [default=yes]?
Name of the storage backend to use (dir, btrfs) [default=btrfs]:
Would you like to create a new btrfs subvolume under /var/lib/lxd (yes/no) [default=yes]:
We detected that you are running inside an unprivileged container.
This means that unless you manually configured your host otherwise,
you will not have enough uid and gid to allocate to your containers.
LXD can re-use your container's own allocation to avoid the problem.
Doing so makes your nested containers slightly less safe as they could
in theory attack their parent container and gain more privileges than
they otherwise would.
Would you like to have your containers share their parent's allocation (yes/no) [default=yes]?
Would you like LXD to be available over the network (yes/no) [default=no]?
Would you like stale cached images to be updated automatically (yes/no) [default=yes]?
Would you like to create a new network bridge (yes/no) [default=yes]?
What should the new bridge be called [default=lxdbr0]?
What IPv4 address should be used (CIDR subnet notation, “auto” or “none”) [default=auto]?
What IPv6 address should be used (CIDR subnet notation, “auto” or “none”) [default=auto]?
LXD has been successfully configured.
root@c1:~# lxc storage list
| default | | btrfs | /var/lib/lxd/storage-pools/default | 1 |
In your case, I’d suggest deleting /var/lib/lxd/storage-pools/default if this somehow exists without a storage pool being listed in lxc storage list and then run the interactive lxd init which will have the special btrfs nesting handling.
I’ve had good luck with simply running lxd init --auto inside of the nested container. A subsequent lxc info will show that the btrfs storage driver is in use.
You’re right! my bad, I didn’t realize that the behavior changed somewhere along the way. Running 2.0.x inside of a container behaves like I described, but apparently that no longer works with 2.21 inside the container.
If automation is your goal, and --auto can no longer do this for us… I discovered that running lxc storage create default btrfs source=/var/lib/lxd/storage-pools/default will create the storage pool successfully, if you do it prior to lxd init which would create the default ‘dir’ pool, which would then it would be in the way.
So it looks like
Either create and configure everything about lxd with the command line (don’t run lxd init)
or more simply, create a differently named btrfs pool and adjust the default profile accordingly
or less simply, recreate the default pool as btrfs, but I’d suspect having to unlink it from the default profile, temporarily
I’ve been running 3.0 with nested 2.0.x in my CI and so hadn’t noticed
I just wanted to add that some times when re-setting up lxd or recreating storage pools for testing, etc. I have had to take a deeper approach to reset the storage pools. I typically use a raw block device, such as /dev/sdb, allocated completely for the pool. Maybe there is a simpler way or a better way.
