I have encountered the following situation, anyone any comment? I have checked two times and the mentioned device(sda) newly created and empty.
Regards.
root@pinehost1:~# lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What IP address or DNS name should be used to reach this node? [default=192.168.1.20]:
Are you joining an existing cluster? (yes/no) [default=no]:
What name should be used to identify this node in the cluster? [default=pinehost1]:
Setup password authentication on the cluster? (yes/no) [default=no]:
Do you want to configure a new local storage pool? (yes/no) [default=yes]:
Name of the storage backend to use (btrfs, dir, lvm) [default=btrfs]:
Create a new BTRFS pool? (yes/no) [default=yes]:
Would you like to use an existing empty block device (e.g. a disk or partition)? (yes/no) [default=no]: yes
Path to the existing block device: /dev/sda
Do you want to configure a new remote storage pool? (yes/no) [default=no]:
Would you like to configure LXD to use an existing bridge or host interface? (yes/no) [default=no]:
Would you like stale cached images to be updated automatically? (yes/no) [default=yes]:
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]:
Error: Failed to create storage pool "local": Failed to format block device: Failed to run: mkfs.btrfs -L local /dev/sda: /dev/sda appears to contain a partition table (dos).
ERROR: use the -f option to force overwrite of /dev/sda
Sure, actually the issue comes from when adding storage to the cluster. Here is another error message.
root@pinehost1:~# lxc storage create local btrfs
Error: Failed to format block device: Failed to run: mkfs.btrfs -L local /dev/sda1: /dev/sda1 appears to contain an existing filesystem (btrfs).
ERROR: use the -f option to force overwrite of /dev/sda1
root@pinehost3:~# fdisk -l /dev/sda
Disk /dev/sda: 14.5 GiB, 15552479232 bytes, 30375936 sectors
Disk model: Ultra Fit
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sda1 2048 30375935 30373888 14.5G 83 Linux
root@pinehost3:~# gdisk -l /dev/sda
GPT fdisk (gdisk) version 1.0.3
Partition table scan:
MBR: MBR only
BSD: not present
APM: not present
GPT: not present
Found invalid GPT and valid MBR; converting MBR to GPT format
in memory.
Warning! Secondary partition table overlaps the last partition by
33 blocks!
You will need to delete this partition or resize it in another utility.
Disk /dev/sda: 30375936 sectors, 14.5 GiB
Model: Ultra Fit
Sector size (logical/physical): 512/512 bytes
Disk identifier (GUID): C5E14FCA-448F-477E-809C-8142CC26209E
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 30375902
Partitions will be aligned on 2048-sector boundaries
Total free space is 2014 sectors (1007.0 KiB)
Number Start (sector) End (sector) Size Code Name
1 2048 30375935 14.5 GiB 8300 Linux filesystem
