distro:
| Distributor ID: | Ubuntu |
| Description: | Ubuntu 18.04.3 LTS |
| Release: | 18.04 |
| Codename: | bionic |
snap info lxd
installed: 3.18 (12631) 57MB -
kernel:
Linux 5.3.0-24-generic #26~18.04.2-Ubuntu SMP Tue Nov 26 12:34:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
start:
Error: Common start logic: Failed to start device ‘vda’: Could not mount storage volume “XXXX” of type “custom” on storage pool “syspool”: Failed to mount ZFS filesystem: Failed to run: zfs mount syspool/custom/XXXX: cannot mount ‘syspool/custom/XXXX’: filesystem already mounted.
Try lxc info --show-log weed for more info
If I check with zfs mount it’s not mounted.
Only a host reboot solved the issue.
