Hi.
I have been having issues with actually doing anything with the software. I am not able to run any lxc/d commands on a Ubuntu server 20.04 system.
I got this error:
lxc profile create bridged
Error: Get “http://unix.socket/1.0”: dial unix /var/snap/lxd/common/lxd/unix.soc ket: connect: connection refused
And started looking for solutions. I ran these commands, based on what I found.
newgrp lxd
sudo usermod -a -G lxd $(whoami)
Which didn’t work. And then i ran this command, with the following output.
sudo lxd --debug --group lxd
INFO[05-18|18:09:13] LXD 4.0.6 is starting in normal mode path=/var/snap/lxd/common/lxd
INFO[05-18|18:09:13] Kernel uid/gid map:
INFO[05-18|18:09:13] - u 0 0 4294967295
INFO[05-18|18:09:13] - g 0 0 4294967295
INFO[05-18|18:09:13] Configured LXD uid/gid map:
INFO[05-18|18:09:13] - u 0 1000000 1000000000
INFO[05-18|18:09:13] - g 0 1000000 1000000000
INFO[05-18|18:09:13] Kernel features:
INFO[05-18|18:09:13] - closing multiple file descriptors efficiently: no
INFO[05-18|18:09:13] - netnsid-based network retrieval: yes
INFO[05-18|18:09:13] - pidfds: yes
INFO[05-18|18:09:13] - uevent injection: yes
INFO[05-18|18:09:13] - seccomp listener: yes
INFO[05-18|18:09:13] - seccomp listener continue syscalls: yes
INFO[05-18|18:09:13] - seccomp listener add file descriptors: no
INFO[05-18|18:09:13] - attach to namespaces via pidfds: no
INFO[05-18|18:09:13] - safe native terminal allocation : yes
INFO[05-18|18:09:13] - unprivileged file capabilities: yes
INFO[05-18|18:09:13] - cgroup layout: hybrid
WARN[05-18|18:09:13] - Couldn't find the CGroup blkio.weight, disk priority will be ignored
WARN[05-18|18:09:13] - Couldn't find the CGroup memory swap accounting, swap limits will be ignored
INFO[05-18|18:09:13] - shiftfs support: yes
INFO[05-18|18:09:13] Initializing local database
DBUG[05-18|18:09:13] Initializing database gateway
DBUG[05-18|18:09:13] Start database node id=1 address= role=voter
INFO[05-18|18:09:13] Starting /dev/lxd handler:
INFO[05-18|18:09:13] - binding devlxd socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[05-18|18:09:13] REST API daemon:
INFO[05-18|18:09:13] - binding Unix socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[05-18|18:09:13] Initializing global database
DBUG[05-18|18:09:13] Dqlite: attempt 0: server 1: connected
INFO[05-18|18:09:13] Firewall loaded driver "nftables"
INFO[05-18|18:09:13] Initializing storage pools
DBUG[05-18|18:09:13] Initializing and checking storage pool "default"
DBUG[05-18|18:09:13] Mount started driver=btrfs pool=default
DBUG[05-18|18:09:13] Mount finished driver=btrfs pool=default
EROR[05-18|18:09:13] Failed to start the daemon: Failed initializing storage pool "default": Source path '/var/snap/lxd/common/lxd/storage-pools/default' isn't btrfs
INFO[05-18|18:09:13] Starting shutdown sequence
INFO[05-18|18:09:13] Closing the database
INFO[05-18|18:09:13] Stop database gateway
INFO[05-18|18:09:14] Stopping REST API handler:
INFO[05-18|18:09:14] - closing socket socket=/var/snap/lxd/common/lxd/unix.socket
INFO[05-18|18:09:14] Stopping /dev/lxd handler:
INFO[05-18|18:09:14] - closing socket socket=/var/snap/lxd/common/lxd/devlxd/sock
INFO[05-18|18:09:14] Unmounting temporary filesystems
INFO[05-18|18:09:14] Done unmounting temporary filesystems
Error: Failed initializing storage pool "default": Source path '/var/snap/lxd/common/lxd/storage-pools/default' isn't btrfs
And when looking for that specific error, I didn’t find any solution that seemed to do the trick.
Any troubleshooting steps I might have missed, or a solution I didn’t find?
