I am having problems adding a new node to an existing cluster.
Existing Cluster has
- two nodes
- two storage pools:
local (type: dir) (added during lxd init)
ssdpool (type: lvm) (added by CLI after cluster of two nodes created)
Output from lxd init run on first node:
core.https_address: 10.20.16.52:8443
core.trust_password: ****** (redacted)
networks: []
storage_pools:
- config: {}
driver: dir
- config: {}
nictype: bridged
parent: br0
pool: local
cluster:
server_name: devlxd1
enabled: true
member_config: []
cluster_address: ""
cluster_certificate: ""
server_address: ""
cluster_password: ""
Output from lxd init run on second node after joining the cluster hosted by the first node above:
config: {}
networks: []
storage_pools: []
profiles: []
cluster:
server_name: devlxd2
enabled: true
member_config:
- entity: storage-pool
key: source
value: ""
description: '"source" property for storage pool "local"'
cluster_address: 10.20.16.52:8443
cluster_certificate: |
-----BEGIN CERTIFICATE-----
MIICCDCCAY2gAwIBAgIRAOow6vt74BMJxq5BkdtvQLcwCgYIKoZIzj0EAwMwNTEc
... redacted ...
wYElArIaNEji6+Y9agaNb1HTaifeGbODVXW/FnebIL0sh2+bqVscmJXsVkc=
-----END CERTIFICATE-----
server_address: 10.20.16.53:8443
cluster_password: ***** (redacted)
I added the second storage pool to the nodes, and then the cluster, via CLI:
ptgs-MacBook-Pro:~ pgarneau$ lxc storage create --target devlxd1 ssdpool lvm source=lxdstore
Storage pool ssdpool pending on member devlxd1
ptgs-MacBook-Pro:~ pgarneau$ lxc storage create --target devlxd2 ssdpool lvm source=lxdstore
Storage pool ssdpool pending on member devlxd2
ptgs-MacBook-Pro:~ pgarneau$ lxc storage create ssdpool lvm
Storage pool ssdpool created
After a period of time successfully running the two node cluster, I attempted to add a new node to the cluster. Output from lxd init run on the new node in an attempt to add a third node to the cluster:
ubuntu@devlxd3:~$ sudo lxd init
Would you like to use LXD clustering? (yes/no) [default=no]: yes
What name should be used to identify this node in the cluster? [default=devlxd3]:
What IP address or DNS name should be used to reach this node? [default=10.20.16.70]:
Are you joining an existing cluster? (yes/no) [default=no]: yes
IP address or FQDN of an existing cluster node: 10.20.16.52
Cluster fingerprint: 19e991543d168bc26290243202ad06ca635d3c64c26af1352a0c17ae6ef99ebe
You can validate this fingerprint by running "lxc info" locally on an existing node.
Is this the correct fingerprint? (yes/no) [default=no]: yes
Cluster trust password:
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose "source" property for storage pool "local":
Choose "lvm.vg_name" property for storage pool "ssdpool": lxdstore
Choose "source" property for storage pool "ssdpool": lxdstore
Would you like a YAML "lxd init" preseed to be printed? (yes/no) [default=no]: yes
config: {}
networks: []
storage_pools: []
profiles: []
cluster:
server_name: devlxd3
enabled: true
member_config:
key: source
value: ""
key: lvm.vg_name
value: lxdstore
description: '"lvm.vg_name" property for storage pool "ssdpool"'
key: source
value: lxdstore
description: '"source" property for storage pool "ssdpool"'
... redacted ...
server_address: 10.20.16.70:8443
The above attempt of lxd init run on the third node failed with the first error message.
First error message (I do not have precise error message warning, but it was fairly close to the following):
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Mismatching config for storage pool ssdpool: different values for keys: lvm.thinpool_name
I had not set thinpool_name, and therefore, I did not know what LXD wanted. The online docs state there is a default value for this config item, but it was seemingly not being used by the app. The lxd init process was not asking me for a value for thinpool_name.
I tried these commands to get information, but the command did not return anything:
ptgs-MacBook-Pro:~ pgarneau$ lxc storage get ssdpool lvm.vg_name
ptgs-MacBook-Pro:~ pgarneau$ lxc storage get ssdpool lvm.thinpool_name
I looked for information via Google search, github PRs, github README.md (which led me to lxd sql).
I figured I would need to go to the database since the “lxc storage” commands above were not providing information.
Before working with the database, I tried removing, then reinstalling, lxd on the node I was trying to add to the existing cluster.
sudo apt remove lxd
sudo apt install lxd
I attempted to add the node to the existing cluster. The lxd init
process failed again, but I started getting the second error.
Second error message:
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Failed to create storage pool 'ssdpool': Volume group "lxdstore" is already used by LXD
I performed a local and global dump, and then looked to the storage_pools_config table.
ubuntu@devlxd1:~$ lxd sql global "select * from storage_pools_config"
| id | storage_pool_id | node_id | key | value |
| 1 | 1 | 1 | source | /var/snap/lxd/common/lxd/storage-pools/local |
| 2 | 1 | 2 | source | /var/snap/lxd/common/lxd/storage-pools/local |
| 5 | 2 | 1 | source | lxdstore |
| 6 | 2 | 1 | volatile.initial_source | lxdstore |
| 7 | 2 | 1 | lvm.vg_name | lxdstore |
| 8 | 2 | 2 | lvm.vg_name | lxdstore |
| 9 | 2 | 2 | source | lxdstore |
| 10 | 2 | 2 | volatile.initial_source | lxdstore |
I figured the problem was that I did not originally provide setting for lvm.thinpool_name.
Therefore, I added
INSERT INTO storage_pools_config VALUES(11,2,1,'lvm.thinpool_name','LXDThinPool');
INSERT INTO storage_pools_config VALUES(12,2,2,'lvm.thinpool_name','LXDThinPool');
I tried to join the node to the cluster, but still cannot join the node to the cluster.
Choose "lvm.thinpool_name" property for storage pool "ssdpool": LXDThinPool
config: {}
networks: []
storage_pools: []
profiles: []
cluster:
enabled: true
member_config:
key: lvm.thinpool_name
value: LXDThinPool
description: '"lvm.thinpool_name" property for storage pool "ssdpool"'
key: lvm.vg_name
value: lxdstore
key: source
value: lxdstore
key: source
value: ""
... redacted ...
Interestingly enough, now the lxd init process is asking me for a value for lvm.thinpool_name
Now, when I try the same lxc storage
commands from above to get information, nothing is returned for lvm.vg_name
, but lvm.thinpool_name
does return a value:
ptgs-MacBook-Pro:~ pgarneau$lxc storage get ssdpool lvm.vg_name
ptgs-MacBook-Pro:~ pgarneau$lxc storage get ssdpool lvm.thinpool_name
LXDThinPool
I have attempted deleting the two records I added above for lvm.thinpool_name, and now I can recreate the lxd init process not asking for thinpool_name, but the third node still fails to be added to the cluster.
I’ve seen from other posts that the response from lvdisplay was desired. The lvdisplay output is quite lengthy from the first two nodes, but the output for lvdisplay for the node I am trying to add to the cluster is:
ubuntu@devlxd3:~$ sudo lvdisplay
--- Logical volume ---
LV Name LXDThinPool
VG Name lxdstore
LV UUID oDczAs-A42f-UBJ5-hoYj-bPvq-EL4m-KRlZNk
LV Write Access read/write
LV Creation host, time devlxd3, 2020-03-19 21:55:50 +0000
LV Pool metadata LXDThinPool_tmeta
LV Pool data LXDThinPool_tdata
LV Status available
# open 0
LV Size 693.69 GiB
Allocated pool data 0.00%
Allocated metadata 1.84%
Current LE 177585
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 253:2
At this point, I am unable to add a 3rd node to the LXD cluster.
Could you help me find the solution to my issues of joining another node to the cluster? I am hoping to join a total of three new nodes to the cluster, but I am stuck right now joining the first node to the original two nodes in the cluster.
I am happy to provide more information if requested.
Thank you.
