Hi. We have a setup where we want to run waydroid (lineageOS) in an LXC container. The host os is a linux-from-scratch-type distro on an embedded arm platform.
We have a script for starting the container:
$ cat /bin/container
#!/usr/bin/env sh
lxc_args="-P /etc/lxc -n waydroid"
rootfs="/run/twist_rootfs"
bridge="br0"
start() {
ip link add name "$bridge" type bridge
ip link set dev "$bridge" up
ip addr add 192.168.10.1/24 brd + dev "$bridge"
sysctl -w net.ipv4.ip_forward=1
iptables -I INPUT -i "$bridge" -p udp --dport 67 -j ACCEPT
iptables -I INPUT -i "$bridge" -p tcp --dport 67 -j ACCEPT
iptables -I INPUT -i "$bridge" -p udp --dport 53 -j ACCEPT
iptables -I FORWARD -i "$bridge" -j ACCEPT
iptables -I FORWARD -o "$bridge" -j ACCEPT
iptables -t nat -A POSTROUTING -s 192.168.10.0/24 -j MASQUERADE
mkdir /run/waydroid
dnsmasq -u nobody --strict-order --bind-interfaces --pid-file=/run/waydroid/dnsmasq.pid --listen-address 192.168.10.1 --dhcp-range 192.168.10.2,192.168.10.10 --dhcp-lease-max=253 --dhcp-no-override --except-interface=lo --interface="$bridge" --dhcp-leasefile=/run/waydroid/dnsmasq."$bridge".leases --dhcp-authoritative
mkdir -p $rootfs
mkdir -p /mnt/base/twist-data
mkdir -p /mnt/base/host-permissions
mount /mnt/base/system.img $rootfs
mount -o remount,ro /mnt/base/system.img $rootfs
mount /mnt/base/vendor.img $rootfs/vendor
mount -o remount,ro /mnt/base/vendor.img $rootfs/vendor
mount -o bind /etc/lxc/waydroid.prop $rootfs/vendor/waydroid.prop
chmod 777 -R /run/xdg
chmod 777 -R /dev/ashmem
chmod 666 -R /dev/binder
chmod 666 -R /dev/hwbinder
chmod 666 -R /dev/vndbinder
chmod 777 -R /dev/dri
chmod 777 -R /dev/fb0
chmod 777 -R /dev/video0
chmod 777 -R /dev/video1
chmod 777 -R /dev/video2
chmod 777 -R /dev/video3
lxc-start -l debug -o /root/waydroid.log $lxc_args -- /init
stop() {
lxc-stop $lxc_args -k
umount $rootfs/vendor/waydroid.prop
umount $rootfs
kill -9 $(cat /run/waydroid/dnsmasq.pid)
rm -rf /run/waydroid
iptables -t nat -D POSTROUTING -s 192.168.10.0/24 -j MASQUERADE
iptables -D FORWARD -o "$bridge" -j ACCEPT
iptables -D FORWARD -i "$bridge" -j ACCEPT
iptables -D INPUT -i "$bridge" -p udp --dport 53 -j ACCEPT
iptables -D INPUT -i "$bridge" -p tcp --dport 67 -j ACCEPT
iptables -D INPUT -i "$bridge" -p udp --dport 67 -j ACCEPT
sysctl -w net.ipv4.ip_forward=0
ip link del dev "$bridge"
shell() {
lxc-attach $lxc_args sh
logcat() {
lxc-attach $lxc_args logcat
top() {
lxc-top $lxc_args
info() {
lxc-info $lxc_args
case "$1" in
start)
start
stop)
stop
shell)
shell
logcat)
logcat
top)
top
info)
info
echo "Usage: $0 {start|stop|shell|logcat|top|info}"
exit 1
esac
If I run container start, then attach and either set up a manual IP address on 192.168.10.0/24 or use dhclient to get one (which works), I get a nice address I can ping from the network namespace, but I canât reach it from the outside.
The host side has this:
5: br0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether fe:c6:34:10:a7:c0 brd ff:ff:ff:ff:ff:ff
inet 192.168.10.1/24 brd 192.168.10.255 scope global br0
inet6 fe80::30c6:8bff:fe24:476c/64 scope link
6: vethB0ETE3@if2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br0 state UP group default qlen 1000
link/ether fe:c6:34:10:a7:c0 brd ff:ff:ff:ff:ff:ff link-netns ns1
inet6 fe80::fcc6:34ff:fe10:a7c0/64 scope link
and the container side this:
[voctavio-2:~] $ ip netns exec ns1 ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
inet6 ::1/128 scope host
2: eth0@if6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:f9:d3:03 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet 192.168.10.4/24 brd 192.168.10.255 scope global eth0
inet6 fe80::216:3eff:fef9:d303/64 scope link
When I ping or try to add a default route:
[voctavio-2:~] $ ip netns exec ns1 ping 192.168.10.1
PING 192.168.10.1 (192.168.10.1): 56 data bytes
ping: sendto: Network is unreachable
[voctavio-2:~] $ ip netns exec ns1 ip route add default via 192.168.10.1
RTNETLINK answers: Network is unreachable
If I manually create a new network namespace with a new veth pair and attach it to the same bridge, it works as I would expect.
My config files:
[voctavio-2:~] $ cat /etc/lxc/default.conf
lxc.net.0.type = veth
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.hwaddr = 00:16:3e:xx:xx:xx
[voctavio-2:~] $ cat /etc/lxc/waydroid.prop
debug.stagefright.ccodec=0
ro.hardware.gralloc=default
ro.hardware.egl=swiftshader
ro.hardware.camera=v4l2
ro.opengles.version=196608
waydroid.system_ota=https://ota.waydro.id/system/lineage/waydroid_x86_64/VANILLA.json
waydroid.vendor_ota=https://ota.waydro.id/vendor/waydroid_x86_64/MAINLINE.json
waydroid.tools_version=1.2.0
ro.vndk.lite=true
ro.product.waydroid.model=Jetson-AGX
waydroid.host.user=root
waydroid.host.uid=1000
waydroid.host.gid=1000
waydroid.xdg_runtime_dir=/run/xdg
waydroid.pulse_runtime_path=/run/xdg/pulse
waydroid.wayland_display=wayland-0
waydroid.stub_sensors_hal=1
[voctavio-2:~] $ cat /etc/lxc/waydroid/config
# Twist LXC Config
lxc.rootfs.path = /run/twist_rootfs
lxc.uts.name = waydroid
lxc.arch = arm64
lxc.autodev = 0
# lxc.autodev.tmpfs.size = 25000000
lxc.apparmor.profile = unconfined
lxc.init.cmd = /init
lxc.mount.auto = cgroup:ro sys:ro proc
lxc.net.0.link = br0
lxc.net.0.name = eth0
lxc.net.0.hwaddr = 00:16:3e:f9:d3:03
lxc.net.0.mtu = 1500
lxc.console.path = none
lxc.include = /etc/lxc/waydroid/config_nodes
lxc.hook.post-stop = /dev/null
[voctavio-2:~] $ cat /etc/lxc/waydroid/config_nodes
lxc.mount.entry = tmpfs dev tmpfs nosuid 0 0
lxc.mount.entry = /dev/zero dev/zero none bind,create=file,optional 0 0
lxc.mount.entry = /dev/null dev/null none bind,create=file,optional 0 0
lxc.mount.entry = /dev/full dev/full none bind,create=file,optional 0 0
lxc.mount.entry = /dev/ashmem dev/ashmem none bind,create=file,optional 0 0
lxc.mount.entry = /dev/fuse dev/fuse none bind,create=file,optional 0 0
lxc.mount.entry = /dev/char dev/char none bind,create=dir,optional 0 0
lxc.mount.entry = /dev/dri dev/dri none bind,create=dir,optional 0 0
lxc.mount.entry = /dev/fb0 dev/fb0 none bind,create=file,optional 0 0
lxc.mount.entry = /dev/binder dev/binder none bind,create=file,optional 0 0
lxc.mount.entry = /dev/vndbinder dev/vndbinder none bind,create=file,optional 0 0
lxc.mount.entry = /dev/hwbinder dev/hwbinder none bind,create=file,optional 0 0
lxc.mount.entry = none dev/pts devpts defaults,mode=644,ptmxmode=666,create=dir 0 0
lxc.mount.entry = /dev/uhid dev/uhid none bind,create=file,optional 0 0
lxc.mount.entry = tmpfs mnt tmpfs mode=0755,uid=0,gid=1000
lxc.mount.entry = /mnt/base/twist-data data none bind 0 0
lxc.mount.entry = /mnt/base/host-permissions vendor/etc/host-permissions none bind,optional 0 0
lxc.mount.entry = /run run none rbind,create=dir 0 0
lxc.mount.entry = /sys/kernel/debug sys/kernel/debug none rbind,create=dir,optional 0 0
lxc.mount.entry = tmpfs mnt_extra tmpfs nodev 0 0
lxc.mount.entry = tmpfs var tmpfs nodev 0 0
lxc.mount.entry = /var/run var/run none rbind,create=dir,optional 0 0
lxc.mount.entry = tmpfs tmp tmpfs nodev 0 0
Any ideas on how to get this bridge up?
