I’m having difficulties to run a unprivileged container using LXD, when I launch an alpine container (teste) with this config, it fails asking for permissions on the /var/lib/lxd, permissions that are already there, here is the step by step:
$ lxc config show teste
boot.autostart: "true"
image.architecture: amd64
image.description: Alpine edge amd64 (20210906_13:00)
image.os: Alpine
image.release: edge
image.serial: "20210906_13:00"
image.type: squashfs
image.variant: default
security.idmap.base: "1000000"
security.idmap.size: "65536"
security.privileged: "false"
volatile.base_image: a5cd77b17561dc20d7cefd3b482301dc43923b10fe6887a1a7593b77b7ac5e46
volatile.idmap.base: "0"
volatile.uuid: 89f366b9-bc8d-4ac2-9a55-dfeb132f7184
devices: {}
$ lxc start teste
Error: Failed to run: /path/to/lxd forkstart teste /var/lib/lxd/containers /var/log/lxd/teste/lxc.conf:
Try `lxc info --show-log teste` for more info
$ lxc info --show-log teste
Remote: unix://
Created: 2021/09/23 15:55 UTC
Status: Stopped
Type: container
Profiles: default
Log:
lxc teste 20210924111701.964 WARN cgfsng - cgroups/cgfsng.c:cg_hybrid_get_controllers:657 - Found hierarchy not under /sys/fs/cgroup: "/dev/cgroups_antivirus rw,relatime shared:146 - cgroup memory rw,memory
lxc teste 20210924111701.974 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.monitor.teste"
lxc teste 20210924111701.993 WARN cgfsng - cgroups/cgfsng.c:mkdir_eexist_on_last:1152 - File exists - Failed to create directory "/sys/fs/cgroup/cpuset//lxc.payload.teste"
lxc teste 20210924111702.145 ERROR start - start.c:print_top_failing_dir:98 - Permission denied - Could not access /var/lib/lxd. Please grant it x access, or add an ACL for the container root
lxc teste 20210924111702.162 ERROR sync - sync.c:__sync_wait:36 - An error occurred in another process (expected sequence number 3)
lxc teste 20210924111702.164 WARN network - network.c:lxc_delete_network_priv:3185 - Failed to rename interface with index 3 from "eth0" to its initial name "veth4d0ebce6"
lxc teste 20210924111702.166 ERROR start - start.c:__lxc_start:1999 - Failed to spawn container "teste"
lxc teste 20210924111702.166 WARN start - start.c:lxc_abort:1013 - No such process - Failed to send SIGKILL via pidfd 26 for process 2715474
lxc teste 20210924111702.198 ERROR lxccontainer - lxccontainer.c:wait_on_daemonized_start:860 - Received container state "ABORTING" instead of "RUNNING"
lxc 20210924111702.391 WARN commands - commands.c:lxc_cmd_rsp_recv:126 - Connection reset by peer - Failed to receive response for command "get_state"
The /var/lib/lxd already has x permission for everyone, so I’ve tried follow the permissions from the container rootfs using namei:
$ namei -mvo /var/lib/lxd/storage-pools/default/containers/teste/rootfs/
| Permission | User | Group | Dir |
| drwxrwxr-x | root | root | var |
| drwxr-xr-x | root | root | lib |
| drwx–x–x | root | root | lxd |
| drwx–x–x | root | root | storage-pools |
| drwx–x–x | root | root | default |
| drwx–x–x | root | root | containers |
| d–x------ | root | root | teste |
| drwxr-xr-x | 1000000 | 1000000 | rootfs |
The only directory without x or ACL for others is the /var/lib/lxd/storage-pools/default/containers/teste, I’ve tried to change and test if that could fix the errors, but every time I try to start the container the permissions change back to the original d–x------
So here is where I’m stuck and asking for help, any input is appreciated!
Also just to be clear my setup is a QNAP NAS, so is a heavily customized Linux, I’m aware this could be de cause why only privileged container are running.
