I have my bootstrap node up and running with:
incus cluster enable vmscloud-incus
I want to add an incus member server to the cluster. I executed the command below on the new member server providing the address of the server.
incus config set cluster.https_address 172.16.1.65:8443
I needed to clear the previously defined port 8443:
incus config set core.https_address=
Back on the bootstrap server:
scott@vmscloud-incus:~$ incus cluster add vmsfog-incus
Member vmsfog-incus join token:
eyJzZXJ2ZXJfbmFtZSI6InZtc2ZvZy1pbmN1cyIsImZpbmdlcnByaW50IjoiN2E5MzU5YTQzYTQwZmI5MGFjNzU5MGQ4MGZiZWRjYTdkYzc5Y2QxMmY2Nzk5YzM1M2I4OWIwYWRlZWEwMDYwMyIsImFkZHJlc3NlcyI6WyIxNzIuMTYuMS4yMTk6ODQ0MyJdLCJzZWNyZXQiOiI5NmQxMzcwOGE2ZDU4NDBhNjczZDkwMTEzOWFjMThjYTJkOGExZDQ2ZjIzYzY4ZmYzOWI2ZWMzOTkyODJjMjgyIiwiZXhwaXJlc19hdCI6IjIwMjQtMDUtMDhUMjE6MDI6MDkuNTAyODUyODMxWiJ9
Now over on the standalone server that I want to be a member server:
scott@vmsfog-incus:~$ sudo incus admin init
Would you like to use clustering? (yes/no) [default=no]: yes
What IP address or DNS name should be used to reach this server? [default=172.16.1.65]: vmsfog-incus
Are you joining an existing cluster? (yes/no) [default=no]: yes
Please provide join token: eyJzZXJ2ZXJfbmFtZSI6InZtc2ZvZy1pbmN1cyIsImZpbmdlcnByaW50IjoiN2E5MzU5YTQzYTQwZmI5MGFjNzU5MGQ4MGZiZWRjYTdkYzc5Y2QxMmY2Nzk5YzM1M2I4OWIwYWRlZWEwMDYwMyIsImFkZHJlc3NlcyI6WyIxNzIuMTYuMS4yMTk6ODQ0MyJdLCJzZWNyZXQiOiIyZmRlNzJmMzk3ZDE1MjRjZWUyODUyZjU1MzYwYWJiYzZkNWZmYTM2M2NiOWRjYzY3NWMzZDgwNmQ5YzY4ZmI3IiwiZXhwaXJlc19hdCI6IjIwMjQtMDUtMDhUMjA6NDc6MzQuMjAxOTE0Njg5WiJ9
All existing data is lost when joining a cluster, continue? (yes/no) [default=no] yes
Choose "size" property for storage pool "default": 150GiB
Choose "source" property for storage pool "default":
Choose "zfs.pool_name" property for storage pool "default":
Would you like a YAML "init" preseed to be printed? (yes/no) [default=no]:
Error: Failed to join cluster: Failed to initialize member: Failed to initialize storage pools and networks: Failed to update storage pool "default": Config key "size" is cluster member specific
It seems that no matter what I pick for the size & source values, I get this error. Any ideas?
FYI: All systems are running the same incus version.
