I’ve come across a problem with Fedora 41 images — images:fedora/41 and
images:fedora/41/cloud — I have a workaround and I’d like to file a bug report
or even a pull request so that the issue is fixed; I’m asking for help please with the next steps.
In brief the path /run/systemd/nsresource/registry does not exist inside these
images and therefore the systemd-nsresourced service fails to start. Creating
the paths and restarting the service is a workaround.
I guess the issue could be solved in
https://github.com/stgraber/distrobuilder/blob/main/sources/fedora-http.go and
I’d appreciate advice before I go further.
Steps to reproduce
Start with a very simple profile saved in a file called config.yaml:
network: incusbr0
pool: default
Command to launch a test container called f41:
incus launch --no-profiles images:fedora/41 f41 < config.yaml
Command to show status:
incus exec f41 -- systemctl is-failed
Output:
degraded
Command to list failed units:
incus exec f41 -- systemctl --failed
Output:
UNIT LOAD ACTIVE SUB DESCRIPTION
● systemd-nsresourced.service loaded failed failed Namespace Resource Manager
● systemd-nsresourced.socket loaded failed failed Namespace Resource Manager Socket
Legend: LOAD → Reflects whether the unit definition was properly loaded.
ACTIVE → The high-level unit activation state, i.e. generalization of SUB.
SUB → The low-level unit activation state, values depend on unit type.
2 loaded units listed.
Investigation of root cause
Command to set the log level to debug:
incus exec f41 -- systemctl log-level debug
Command to restart the failing service:
incus exec f41 -- systemctl restart systemd-nsresourced.service
Command to view logs:
incus exec f41 -- journalctl -xeu systemd-nsresourced.service
Relevant lines of debug log output:
Dec 11 10:43:44 f41 (esourced)[220]: systemd-nsresourced.service: Executing: /usr/lib/systemd/systemd-nsresourced
Dec 11 10:43:44 f41 systemd-nsresourced[220]: Failed to open registry directory: Read-only file system
Dec 11 10:43:44 f41 systemd-nsresourced[220]: Failed to start up daemon: Read-only file system
Command to check relevant version
incus exec f41 -- rpm --query --file /usr/lib/systemd/systemd-nsresourced
Output:
systemd-256.9-2.fc41.x86_64
Likely relevant C source code:
https://github.com/systemd/systemd/blob/v256.9/src/nsresourced/nsresourced-manager.c
https://github.com/systemd/systemd/blob/v256.9/src/nsresourced/userns-registry.c
From the later I think the relevant directory is
/run/systemd/nsresource/registry.
Neither of the following paths exist inside the container:
/run/systemd/nsresource/registry/run/systemd/nsresource
Workaround
Command to create the two missing directories:
incus exec f41 -- mkdir --parents /run/systemd/nsresource/registry
Command to restart the service:
Command to show the status:
Output:
running
Similarly incus exec f41 -- systemctl --failed now shows
0 loaded units listed.
