I havent test any fedora image for a long time but today I have encountered the following problem, tested with fedora/32 image.
Regards.
lxc launch images:fedora/32 ctest
[root@ctest ~]# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
● dbus-broker.service loaded failed failed D-Bus System Message Bus
● systemd-homed.service loaded failed failed Home Area Manager
● systemd-networkd.service loaded failed failed Network Service
● systemd-resolved.service loaded failed failed Network Name Resolution
● systemd-udev-trigger.service loaded failed failed udev Coldplug all Devices
● dbus.socket loaded failed failed D-Bus System Message Bus Socket
● systemd-journald-audit.socket loaded failed failed Journal Audit Socket
● systemd-networkd.socket loaded failed failed Network Service Netlink Socket
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
[root@ctest ~]# journalctl -p err -n 20
-- Logs begin at Fri 2021-04-30 19:13:22 UTC, end at Fri 2021-04-30 19:13:23 UTC. --
Apr 30 19:13:23 ctest systemd[78]: dbus-broker.service: Failed at step NAMESPACE spawning /usr/bin/dbus-broker-launch: Permission denied
Apr 30 19:13:23 ctest systemd[1]: Failed to start D-Bus System Message Bus.
Apr 30 19:13:23 ctest systemd[81]: systemd-resolved.service: Failed to set up mount namespacing: /run/systemd/unit-root/: Permission denied
Apr 30 19:13:23 ctest systemd[84]: dbus-broker.service: Failed to set up mount namespacing: /run/systemd/unit-root/boot: Permission denied
Apr 30 19:13:23 ctest systemd[84]: dbus-broker.service: Failed at step NAMESPACE spawning /usr/bin/dbus-broker-launch: Permission denied
Apr 30 19:13:23 ctest systemd[81]: systemd-resolved.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-resolved: Permission denied
Apr 30 19:13:23 ctest systemd[1]: Failed to start Network Name Resolution.
Apr 30 19:13:23 ctest systemd[1]: Failed to start Home Area Manager.
Apr 30 19:13:23 ctest systemd[89]: systemd-resolved.service: Failed to set up mount namespacing: /run/systemd/unit-root/: Permission denied
Apr 30 19:13:23 ctest systemd[89]: systemd-resolved.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-resolved: Permission denied
Apr 30 19:13:23 ctest systemd[92]: systemd-resolved.service: Failed to set up mount namespacing: /run/systemd/unit-root/: Permission denied
Apr 30 19:13:23 ctest systemd[92]: systemd-resolved.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-resolved: Permission denied
Apr 30 19:13:23 ctest systemd[95]: systemd-resolved.service: Failed to set up mount namespacing: /run/systemd/unit-root/: Permission denied
Apr 30 19:13:23 ctest systemd[95]: systemd-resolved.service: Failed at step NAMESPACE spawning /usr/lib/systemd/systemd-resolved: Permission denied
