My question may be stupid
When using ZFS as storage, what file system is used inside a container?
Does it inherit from the host, meaning also from ZFS?
Is it not EXT4 or another one?
Are you talking containers, or VMs?
If it’s a container, then it’s a zfs dataset on the host. The container has this mounted inside its chroot environment. It sees no block device.
It’s rather the opposite, what is the file system if on the host it’s ZFS? Is it also ZFS in the container?
I’m not sure how I can make it clearer than this:
For example:
# incus storage list
| default | zfs | zfs/lxd | | 10 | CREATED |
I have a container called “nfsen”. From the host side:
# zfs list zfs/lxd/containers/nfsen
zfs/lxd/containers/nfsen 34.7G 193G 34.7G legacy
# ls -l /var/lib/incus/containers/nfsen
lrwxrwxrwx 1 root root 53 Mar 20 22:50 /var/lib/incus/containers/nfsen -> /var/lib/incus/storage-pools/default/containers/nfsen
# ls -l /var/lib/incus/storage-pools/default/containers/nfsen
total 26
-r-------- 1 root root 7021 Mar 21 10:56 backup.yaml
-rw-r--r-- 1 root root 1050 Jun 10 2020 metadata.yaml
drwxr-xr-x 22 root root 22 Mar 21 10:55 rootfs
drwxr-xr-x 2 root root 7 Jun 10 2020 templates
# ls -li /var/lib/incus/storage-pools/default/containers/nfsen/rootfs/etc/hosts
706 -rw-r--r-- 1 root root 221 Jun 5 2020 /var/lib/incus/storage-pools/default/containers/nfsen/rootfs/etc/hosts
Inside the container, a file such as /etc/hosts
is actually /var/lib/incus/storage-pools/default/containers/nfsen/rootfs/etc/hosts
on the host system, which is the file rootfs/etc/hosts
within the zfs dataset zfs/lxd/containers/nfsen
The container’s view of the same file:
# incus shell nfsen
root@nfsen:~# mount | grep 'on / '
zfs/lxd/containers/nfsen on / type zfs (rw,relatime,idmapped,xattr,posixacl,casesensitive)
root@nfsen:~# ls -li /etc/hosts
706 -rw-r--r-- 1 root root 221 Jun 5 2020 /etc/hosts
What I’m trying to say is: it makes no sense to talk about the file system in the container being something other than the file system in the host, because they are the same file system.
Perfect, that’s exactly the answer I was expecting, sorry for the confusion. I have a MariaDB server in a container, and I’ve seen that it needs to be fine-tuned to get better performance when we’re under ZFS
