Flasher-tool for lts-7.0
Hi, now Incus lts 7.0 is released, I also need to use the corresponding flasher-tool to create images for it. However there is no tag indicating the 7.0 lts version. What official tag should be used for 7.0?
(latest will not always work in future)
IncusOS follows a different release cycle and release numbering scheme than Incus.
The flasher tool was extended to allow the selection of the Incus 7.0 LTS application in flasher-tool: Recognize Incus 7.0 LTS application · lxc/incus-os@d978a8a · GitHub, which is part of IncusOS versions 202605270119 and later.
Thanks for this update. OK, they have a different release cycle. But I expect a future version of flashertool might not be compatible with incus 7.0 lts. If that is true, it could be helpful to mark/tag the newest flashertool version that is compatible for a given lts of incus
IncusOS ships with two separate applicaitons, incus and incus-lts-7.0.
We don’t have different branches of IncusOS itself for monthly Incus or LTS Incus, every build we make provides both applications.
