ForceInstallConfirmation seed customization?
I want to reinstall IncusOS on an x86_64 pc, since I no longer have the original certificate I provisioned it with. I created a new image with the web customizer because I do not have a linux machine to use the go customizer. When booting, I get ‘System check error: IncusOS is already installed on this system; to confirm overwriting, add ForceInstallConfirmation=19963d’, but I don’t see any documentation on how to add that to the seed in the web customizer. Any suggestions?
Hmm, yeah currently there’s no way to set that in the image customizer. It wouldn’t be too hard to add: Add `ForceInstallConfirmation` field to image customizer web UI · Issue #1195 · lxc/incus-os · GitHub
Thanks for adding this. Is there an ETA on when the update will be rolled out to IncusOS image downloader ?
It’s live now. This is a manual deployment so I just forgot that we had a pending UI change that needed to make it onto the server :slight_smile:
