Originally I setup lxd on a storage pool called “default”. Then I decided I’d like to use the storage pool for some other things besides lxd. So I created a dataset to use as an lxd storage pool called “default/lxd” using lxc storage create lxd zfs source=default/lxd
I’ve spent the time to move all my containers over to the new location and am now wanting to cleanup after myself. I tried doing lxc storage delete default but found out I can’t since default/lxd is a subset of default. Which I suppose makes sense.
Is there any way of getting lxd to forget storage pools without deleting the data contained inside them?
