Getting unexplained error 400 when trying to add remote
My incus lives behind a Traefik reverse proxy. The web UI is accessible no problem, but when I try to run the incus remote add incus.example.com https://incus.example.com:443 --token eyJjbGllbnRfbm…, I get the error message Error: http status not ok: 400 Bad Request {}.
I’ve tried setting up the reverse proxy either as an https terminator (incus.example.com), or a tcp forwarder (incus-cli.example.com). The server log is slightly different in either case (untrusted GET vs. matching trusted cert), but the error persists.
Adding the --debug flag shows the json response below, so I know this is actually the incus API responding.
DEBUG  [2025-11-05T17:35:08+01:00] Got response struct from Incus
		"config": {},
		"api_extensions": [
			"storage_zfs_remove_snapshots",
I tried enabling debug on the server, but I see no errors:
$ incus monitor --pretty --loglevel=debug
DEBUG  [2025-11-05T15:48:07+01:00] Event listener server handler started         id=67d5b628-80f7-4512-9112-642b8d7e5f42 local=/var/lib/incus/unix.socket remote=@
DEBUG  [2025-11-05T15:48:12+01:00] Handling API request                          ip="192.168.3.105:53180" method=GET protocol=tls url=/1.0 username=SNIP
DEBUG  [2025-11-05T15:48:12+01:00] Matched trusted cert                          fingerprint=SNIP subject="CN=user@Bruinen.local,O=Linux Containers"
DEBUG  [2025-11-05T15:48:13+01:00] Handling API request                          ip="192.168.3.105:53186" method=GET protocol=tls url=/1.0 username=SNIP
DEBUG  [2025-11-05T15:48:13+01:00] Matched trusted cert                          fingerprint=SNIP subject="CN=user@Bruinen.local,O=Linux Containers"
What more can I do to find out what the error is?
You won’t be able to do anything related to TLS authentication when you have a proxy terminating TLS in the middle.
So you definitely need to use the TCP forwarder approach.
I’d recommend testing that the token works correctly without going through the proxy, if it does, then your proxy is doing something wrong somehow.
I’m not familiar with Traefik but all my production clusters use HAproxy in TCP forwarder/load-balancer and that works perfectly with HTTPS client certificates.
Thank you Stéphane. I also tried bypassing the reverse proxy, but couldn’t find out how to disable client-side the server cert, or generate a cert with an alternative name. If neither is possible, I can still test by forcing the hosts file, but an alt name cert would be preferable.
incus remote add should just prompt for the fingerprint in such cases and then trust the certificate based on that when that (this step is skipped when the certificate is found to be directly valid).
Indeed, and I’m still getting a 400 error with a direct connection:
❯ incus remote add incus.example.com https://100.111.228.5:8443 --token eyJjbGllbnRfbmFtZSI6ImJydWluZW4i…
Certificate fingerprint: 3acb8ba6a7025f1b7400655c646167a16afc0a5bf2e41aec2c91f9ade4230a4a
ok (y/n/[fingerprint])? y
Going back to my original message, where can I see the server-side error that is translated to an http error code on the client?
Is the token still valid on the server side?
incus config trust list-tokens
It was not… but when I created a new one and tried to connect the remote again, I still got the 400 error, both through the reverse proxy and using a direct connection.
Thank you again for your assistance!
Can you create one and then immediately use it with the direct connection, never try to use it through the proxy?
As soon as a token is seen by the server, it gets invalidated, so if your proxy is doing something weird, the token will get invalidated, then when you try to use it directly, you’re getting a failure because no such token exists.
You can try to run incus monitor --pretty on the server side to see all log messages as they happen. Though I don’t know how chatty this particular part of the code is.
We try not to log too much pre-authentication as otherwise someone can use that to DoS the machine by causing a lot of spurious logging.
Server
❯ incus config trust add bruinen
Client bruinen certificate add token:
eyJjbGllbnRfbmFtZSI6ImJydWluZW4iL…
❯ incus monitor --pretty
DEBUG  [2025-11-07T09:04:13+01:00] Event listener server handler started         id=66bc05d4-b594-48d3-bdce-ec06fe5fae28 local=/var/lib/incus/unix.socket remote=@
DEBUG  [2025-11-07T09:04:17+01:00] Matched trusted cert                          fingerprint=f9b3f0c866f84d9d070a2553b6a1f258e3b294585f40817e234c24eee1a41ccf subject="CN=user@Bruinen.local,O=Linux Containers"
DEBUG  [2025-11-07T09:04:17+01:00] Handling API request                          ip="100.106.190.121:55531" method=GET protocol=tls url=/1.0 username=f9b3f0c866f84d9d070a2553b6a1f258e3b294585f40817e234c24eee1a41ccf
DEBUG  [2025-11-07T09:04:17+01:00] Handling API request                          ip="100.106.190.121:55532" method=GET protocol=tls url=/1.0 username=f9b3f0c866f84d9d070a2553b6a1f258e3b294585f40817e234c24eee1a41ccf
Client
❯ incus remote add incus.example.com https://100.111.228.5:8443 --token eyJjbGllbnRfbmFtZSI6ImJydWluZW4iL…
Can you show env | grep -i proxy? Some kind of corporate HTTP proxy would also have the same effect of terminating TLS in a way that prevents the certificate from reaching the server, causing the same error.
The command returns empty on both the sever and client.
Doesn’t the server log show that the client cert is correctly received?
Hmm, actually, I wonder if you’re not facing the opposite problem now, effectively tying to get Incus to add a new entry, using a token when it already trusts you :slight_smile:
What happens if you don’t pass --token XYZ, just incus remote add incus.example.com https://100.111.228.5:8443
Same unfortunately:
I tried removing the token on the server incus config trust revoke-token bruinen and running the command again (with no token available on the server) → still 400.
I added a new token and ran remote add once more → still 400.
So the error must happen before the server checks the token.
I checked that my earlier remote does work on this client:
❯ incus remote ls
|             NAME              |                URL                 |   PROTOCOL    |  AUTH TYPE  | PUBLIC | STATIC | GLOBAL |
| images                        | https://images.linuxcontainers.org | simplestreams | none        | YES    | NO     | NO     |
| incus.int.example.com (current) | https://incus.int.example.com:8443   | incus         | tls         | NO     | NO     | NO     |
| local                         | unix://                            | incus         | file access | NO     | YES    | NO     |
❯ incus ls
Error: Get "https://incus.int.example.com:8443/1.0": tls: failed to verify certificate: x509: certificate is valid for incus-cli.example.com, not incus.int.example.com
❯ subl /etc/hosts # add incus-cli.example.com to hosts
❯ doggo incus.int.example.com
NAME                  TYPE  CLASS  TTL  ADDRESS      NAMESERVER
incus.int.example.com.  A     IN     1s   192.168.3.5  100.100.100.100:53
❯ incus remote set-url incus.int.example.com https://incus-cli.example.com:8443
❯ incus ls
|   NAME    |  STATE  |             IPV4             |                  IPV6                  |      TYPE       | SNAPSHOTS |
| docker    | STOPPED |                              |                                        | CONTAINER       | 0         |
| docker-vm | RUNNING | 192.168.3.105 (enp5s0)       | fd7a:115c:… (tailscale0) | VIRTUAL-MACHINE | 0         |
… but it would be nice to be able to add a remote with the external name and IP.
I just did some testing here covering.
What happens if passing an invalid token:
stgraber@castiana:~$ incus remote add dakara https://dakara.lan:8443 --token='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'
Certificate fingerprint: d4cf6522ef6333095aad61a686767f5e244f263290864064a9aadcfccbf72ae7
Error: No matching certificate add operation found
Passing a valid token for the first time:
stgraber@castiana:~$ incus remote add dakara https://dakara.lan:8443 --token='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'
Client certificate now trusted by server: dakara
Passing a valid or invalid token after the machine has already been trusted:
We never have Incus log http status not ok so that’s not an error that’s coming from our side.
It is however an error that can come out of Zitadel OIDC’s implementation.
Is your server configured with some (potentially broken) OIDC configuration?
If so, the client will always prefer OIDC authentication unless told otherwise with --auth-type=tls, so that may be the problem here.
That was it, great catch!
I do use Authelia for OIDC, and it’s working great, but despite the fact that the tcp forwarder for incus-cli doesn’t use forward auth, I understand that incus itself is trying to use oidc (although I’m having trouble understanding how that would work without a client-side oidc implementation).
A few follow-up questions if you’re not totally fed up with me:
  • (more of an observation) I was able to use incus remote add incus.example.com https://incus.example.com:443 --token eyJjbGllbnRfbmFtZSI6I… --auth-type=tls (the https reverse-proxy)
    • here’s the question: does this mean that my incus server now trusts my reverse-proxy, and that any query coming from that will be authorized (bad)? Or is the auth tied to my client (good)?
  • I still have the issue that the server doesn’t have an alternative name in its cert: incus ls incus.int.example.com:Error: Get “https://incus.int.example.com:8443/1.0”: tls: failed to verify certificate: x509: certificate is valid for incus-cli.example.com, not incus.int.example.com
    • is that something I can work around client-side (–insecure flag to allow invalid server cert) or server-side (add alt name)?
Easiest is to check it. Run incus remote get-client-certificate on your client and go look at incus config trust list and incus config trust show on the server side, if the certificate matches, you’re good, it’s safe end to end. If it doesn’t match, then you’ve trusted an intermediate certificate like that of your proxy.
That’s confusing. Is that your old remote? If so, remove it and add it back, that should get you the certificate fingerprint prompt at which point it will trust that certificate regardless of what the CN is.
The Incus CLI does have a built-in OIDC client. I use that with all my production servers for authentication. Maybe it’s just a config issue on your IdP that’s getting in the way as the CLI requires support for device code authentication.
Thank you for your answers:
  • the cert trusted by the server is that of my client, (incus remote get-client-certificate matches incus config trust show)
  • removing and re-adding the direct connection with the cname mismatch did work after confirmation as you said
  • I’ll leave for another day the discussion of how to debug the server-side oidc integration :slight_smile:
Thank you so much for your help and insights. It’s really cemented my decision to switch to Incus!
