Hi, my snaps refreshed today, currently lxd is at 5.12-3564c08
rev 24615
in latest/candidate
. There is some problem again with gpu enabled containers. At start I’m getting errors like
lxc mycontainer 20230317071925.749 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc mycontainer 20230317071925.749 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc mycontainer 20230317071925.750 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3621 - newuidmap binary is missing
lxc mycontainer 20230317071925.750 WARN conf - ../src/src/lxc/conf.c:lxc_map_ids:3627 - newgidmap binary is missing
lxc mycontainer 20230317071925.750 WARN cgfsng - ../src/src/lxc/cgroups/cgfsng.c:fchowmodat:1619 - No such file or directory - Failed to fchownat(42, memory.oom.group, 1000000000, 0, AT_EMPTY_PATH | AT_SYMLINK_NOFOLLOW )
lxc mycontainer 20230317071925.953 ERROR conf - ../src/src/lxc/conf.c:run_buffer:322 - Script exited with status 1
lxc mycontainer 20230317071925.953 ERROR conf - ../src/src/lxc/conf.c:lxc_setup:4437 - Failed to run mount hooks
lxc mycontainer 20230317071925.953 ERROR start - ../src/src/lxc/start.c:do_start:1272 - Failed to setup container "mycontainer"
lxc mycontainer 20230317071925.953 ERROR sync - ../src/src/lxc/sync.c:sync_wait:34 - An error occurred in another process (expected sequence number 4)
lxc mycontainer 20230317071925.956 WARN network - ../src/src/lxc/network.c:lxc_delete_network_priv:3631 - Failed to rename interface with index 0 from "eth0" to its initial name "veth83025810"
lxc mycontainer 20230317071925.956 ERROR lxccontainer - ../src/src/lxc/lxccontainer.c:wait_on_daemonized_start:878 - Received container state "ABORTING" instead of "RUNNING"
lxc mycontainer 20230317071925.956 ERROR start - ../src/src/lxc/start.c:__lxc_start:2107 - Failed to spawn container "mycontainer"
lxc mycontainer 20230317071925.956 WARN start - ../src/src/lxc/start.c:lxc_abort:1036 - No such process - Failed to send SIGKILL via pidfd 43 for process 9546
lxc 20230317071926.863 ERROR af_unix - ../src/src/lxc/af_unix.c:lxc_abstract_unix_recv_fds_iov:218 - Connection reset by peer - Failed to receive response
lxc 20230317071926.863 ERROR commands - ../src/src/lxc/commands.c:lxc_cmd_rsp_recv_fds:128 - Failed to receive file descriptors for command "get_init_pid"
