I’m looking for some clarification about how to best optimise video performance when connecting via RDP/Spice etc.
My host is Debian 13 with Incus 6.15. The host has a GTX 1050 Ti which I am passing through to a Debian 13 VM, along with an Intel 82580 NIC.
My Windows 11 PC has Incus client and virt-viewer installed and I am currently using incus console debian --type=vga to connect to the Debian VM for daily use as I only want to use Windows 11 for gaming.
The VMs disk is on a ZFS mirror backed by SATA HDDs. It has 2 CPUs from the host and 8GB of RAM.
sudo lspci in the VM shows the Red Hat Virtio GPU and the GTX 1050 Ti
When I connect (which if I understand correctly, is using Spice), there is some video lag.
Is this approach taking advantage of the GTX 1050 Ti in any way? Is there a better approach?
Do I need to do this – https://wiki.debian.org/NvidiaGraphicsDrivers#trixie-550 ? (SecureBoot is enabled on the host and mokutil --sb-state says SecureBoot enable in the guest)
Thanks for any guidance,
Stephen
