Hi all,
Small update:
We reorganised infrastructure and installed ubuntu 20.04 on our host machine and right now try to passthrough one of our 2 gpus to lxd vm.
The machine is visible via lspci -nn
root@k3s-1gpu-node:~# lspci -nn | grep -i nvidia
06:00.0 3D controller [0302]: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB] [10de:1db6] (rev a1)
One thing I noted is that the pci id is different than on the host
mother@node53:~$ sudo lspci -nn | grep -i nvidia
18:00.0 3D controller [0302]: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB] [10de:1db6] (rev a1)
af:00.0 3D controller [0302]: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB] [10de:1db6] (rev a1)
mother@node53:~$ lxc config show k3s-1gpu-node | grep gpu -A 5
volatile.gpu1.last_state.pci.driver: vfio-pci
volatile.gpu1.last_state.pci.slot.name: 0000:af:00.0
volatile.uuid: 61b7e20b-4b93-450d-b8ec-7e6a05ecffab
volatile.vsock_id: "18"
gpu1:
gputype: physical
pci: 0000:af:00.0
type: gpu
- vm-linux-btrfs
mother@node53:~$
IOMMU seems to be working just fine and the card seems to have the right driver:
oot@node53:~# dmesg | grep -E "DMAR|IOMMU"
[ 0.021318] ACPI: DMAR 0x000000005F5CC9D8 000292 (v01 FUJ D3384-B1 00000001 INTL 20091013)
[ 0.021383] ACPI: Reserving DMAR table memory at [mem 0x5f5cc9d8-0x5f5ccc69]
[ 0.448729] DMAR: IOMMU enabled
[ 0.728487] DMAR: Host address width 46
[ 0.728490] DMAR: DRHD base: 0x000000d37fc000 flags: 0x0
[ 0.728497] DMAR: dmar0: reg_base_addr d37fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728501] DMAR: DRHD base: 0x000000e0ffc000 flags: 0x0
[ 0.728507] DMAR: dmar1: reg_base_addr e0ffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728510] DMAR: DRHD base: 0x000000ee7fc000 flags: 0x0
[ 0.728515] DMAR: dmar2: reg_base_addr ee7fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728518] DMAR: DRHD base: 0x000000fbffc000 flags: 0x0
[ 0.728524] DMAR: dmar3: reg_base_addr fbffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728527] DMAR: DRHD base: 0x000000aaffc000 flags: 0x0
[ 0.728532] DMAR: dmar4: reg_base_addr aaffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728535] DMAR: DRHD base: 0x000000b87fc000 flags: 0x0
[ 0.728540] DMAR: dmar5: reg_base_addr b87fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728543] DMAR: DRHD base: 0x000000c5ffc000 flags: 0x0
[ 0.728552] DMAR: dmar6: reg_base_addr c5ffc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728555] DMAR: DRHD base: 0x0000009d7fc000 flags: 0x1
[ 0.728560] DMAR: dmar7: reg_base_addr 9d7fc000 ver 1:0 cap 8d2078c106f0466 ecap f020df
[ 0.728563] DMAR: RMRR base: 0x0000006f5d4000 end: 0x0000006f5e5fff
[ 0.728566] DMAR: RMRR base: 0x000000672bd000 end: 0x0000006f2c4fff
[ 0.728568] DMAR: ATSR flags: 0x0
[ 0.728570] DMAR: ATSR flags: 0x0
[ 0.728572] DMAR: RHSA base: 0x0000009d7fc000 proximity domain: 0x0
[ 0.728575] DMAR: RHSA base: 0x000000aaffc000 proximity domain: 0x0
[ 0.728577] DMAR: RHSA base: 0x000000b87fc000 proximity domain: 0x0
[ 0.728579] DMAR: RHSA base: 0x000000c5ffc000 proximity domain: 0x0
[ 0.728581] DMAR: RHSA base: 0x000000d37fc000 proximity domain: 0x1
[ 0.728583] DMAR: RHSA base: 0x000000e0ffc000 proximity domain: 0x1
[ 0.728585] DMAR: RHSA base: 0x000000ee7fc000 proximity domain: 0x1
[ 0.728588] DMAR: RHSA base: 0x000000fbffc000 proximity domain: 0x1
[ 0.728591] DMAR-IR: IOAPIC id 12 under DRHD base 0xc5ffc000 IOMMU 6
[ 0.728594] DMAR-IR: IOAPIC id 11 under DRHD base 0xb87fc000 IOMMU 5
[ 0.728596] DMAR-IR: IOAPIC id 10 under DRHD base 0xaaffc000 IOMMU 4
[ 0.728598] DMAR-IR: IOAPIC id 18 under DRHD base 0xfbffc000 IOMMU 3
[ 0.728601] DMAR-IR: IOAPIC id 17 under DRHD base 0xee7fc000 IOMMU 2
[ 0.728603] DMAR-IR: IOAPIC id 16 under DRHD base 0xe0ffc000 IOMMU 1
[ 0.728606] DMAR-IR: IOAPIC id 15 under DRHD base 0xd37fc000 IOMMU 0
[ 0.728609] DMAR-IR: IOAPIC id 8 under DRHD base 0x9d7fc000 IOMMU 7
[ 0.728612] DMAR-IR: IOAPIC id 9 under DRHD base 0x9d7fc000 IOMMU 7
[ 0.728614] DMAR-IR: HPET id 0 under DRHD base 0x9d7fc000
[ 0.728617] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[ 0.728618] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[ 0.730404] DMAR-IR: Enabled IRQ remapping in xapic mode
[ 2.098098] DMAR: dmar6: Using Queued invalidation
[ 2.098105] DMAR: dmar5: Using Queued invalidation
[ 2.098109] DMAR: dmar4: Using Queued invalidation
[ 2.098113] DMAR: dmar3: Using Queued invalidation
[ 2.098118] DMAR: dmar2: Using Queued invalidation
[ 2.098132] DMAR: dmar1: Using Queued invalidation
[ 2.098136] DMAR: dmar0: Using Queued invalidation
[ 2.098140] DMAR: dmar7: Using Queued invalidation
[ 2.121043] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 4.194077] megaraid_sas 0000:5e:00.0: DMAR: 32bit DMA uses non-identity mapping
[ 5.116904] qla2xxx 0000:86:00.0: DMAR: 32bit DMA uses non-identity mapping
[ 8.033480] qla2xxx 0000:86:00.1: DMAR: 32bit DMA uses non-identity mapping
[ 10.672322] qla2xxx 0000:d8:00.0: DMAR: 32bit DMA uses non-identity mapping
[ 13.565232] qla2xxx 0000:d8:00.1: DMAR: 32bit DMA uses non-identity mapping
Subsystem: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB] [10de:124a]
Flags: fast devsel, IRQ 233, NUMA node 1
Memory at ed000000 (32-bit, non-prefetchable) [disabled] [size=16M]
Memory at 7e000000000 (64-bit, prefetchable) [disabled] [size=32G]
Memory at 7e800000000 (64-bit, prefetchable) [disabled] [size=32M]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [ac0] Designated Vendor-Specific <?>
Kernel driver in use: vfio-pci
Kernel modules: nvidiafb, nouveau
When I try to install the nvidia driver on the vm I get(from log):
-> Kernel messages:
[ 2.900871] [drm] pci: virtio-vga detected at 0000:04:00.0
[ 2.911600] virtio-pci 0000:04:00.0: vgaarb: deactivate vga console
[ 2.911782] [drm] features: -virgl +edid -resource_blob -host_visible
[ 2.912406] [drm] number of scanouts: 1
[ 2.912411] [drm] number of cap sets: 0
[ 2.912940] [drm] Initialized virtio_gpu 0.1.0 0 for virtio11 on minor 0
[ 2.915344] fbcon: Deferring console take-over
[ 2.915347] virtio_gpu virtio11: [drm] fb0: virtio_gpudrmfb frame buffer device
[ 2.949411] cryptd: max_cpu_qlen set to 1000
[ 2.996650] AVX2 version of gcm_enc/dec engaged.
[ 2.996690] AES CTR mode by8 optimization enabled
[ 6.220654] fbcon: Taking over console
[ 6.221065] virtio_gpu virtio11: [drm] drm_plane_enable_fb_damage_clips() not called
[ 6.221134] Console: switching to colour frame buffer device 160x50
[ 267.451831] nvidia: loading out-of-tree module taints kernel.
[ 267.451845] nvidia: module license 'NVIDIA' taints kernel.
[ 267.451851] Disabling lock debugging due to kernel taint
[ 267.502765] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 267.514734] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[ 267.514740] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
NVRM: BAR0 is 0M @ 0x0 (PCI:0000:06:00.0)
[ 267.516654] nvidia: probe of 0000:06:00.0 failed with error -1
[ 267.516678] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 267.516679] NVRM: None of the NVIDIA devices were initialized.
[ 267.517839] nvidia-nvlink: Unregistered Nvlink Core, major device number 235
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
The error is clear
Right now the only way aou I found on the internet is to add realloc option to grub options
GRUB_CMDLINE_LINUX_DEFAULT="iommu=pt intel_iommu=on rd.driver.blacklist=nouveau nouveau.modeset=0 vfio-pci.ids=10de:1db6 kvm.ignore_msrs=1 tsx=on tsx_async_abort=off pcie_acs_override=downstream,multifunction nofb nomodeset pci=realloc"
@stgraber maybe you came across a similar problem?
Thanks
Mateusz
