Gw-priority for OCI instances
When running OCI based instances, is there any equivalent of the Docker gw-priority flag for networks?
I’m running into a challenge where an instance has two bridged NICs attached. The second is taking priority for the default route. This can be corrected by adjusting internally on the instance but would be good to lift that config out to the incus level.
