Encountering the same issue. Following @freeekanayaka 's instructions, here are the logs:
(Note: using macvlan instead of bridge, and the port for each node is 8343 instead of 8443. Yet somehow LXD still tries 8443 and the connection gets refused. Firewall allows both 8343 and 8443).
Node 1 (10.0.0.150, debixps)
t=2021-09-26T23:48:40-0700 lvl=dbug msg="Sending heartbeat request" address=10.0.0.100:8343
t=2021-09-26T23:48:40-0700 lvl=dbug msg="Successful heartbeat" address=10.0.0.100:8343
t=2021-09-26T23:48:40-0700 lvl=dbug msg="Completed heartbeat round" address=10.0.0.150:8343 duration=912.109428ms
t=2021-09-26T23:48:49-0700 lvl=dbug msg="Database error: &errors.errorString{s:\"No such object\"}"
t=2021-09-26T23:48:49-0700 lvl=warn msg="Failed to retrieve cluster member" err="No such object"
t=2021-09-26T23:48:49-0700 lvl=dbug msg="Starting heartbeat round" address=10.0.0.150:8343 mode=normal
t=2021-09-26T23:48:49-0700 lvl=dbug msg="Heartbeat updating local raft members" members="[{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx} {NodeInfo:{ID:3 Address:10.0.0.11:8343 Role:spare} Name:} {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}]"
t=2021-09-26T23:48:49-0700 lvl=eror msg="Unaccounted raft node(s) not found in 'nodes' table for heartbeat: {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}"
t=2021-09-26T23:49:40-0700 lvl=dbug msg="Sending heartbeat request" address=10.0.0.100:8343
t=2021-09-26T23:49:40-0700 lvl=dbug msg="Successful heartbeat" address=10.0.0.100:8343
t=2021-09-26T23:49:40-0700 lvl=dbug msg="Completed heartbeat round" address=10.0.0.150:8343 duration=1.321426187s
t=2021-09-26T23:49:46-0700 lvl=dbug msg="Matched trusted cert" fingerprint=bd8b3ae22ab3898bd2d8a01e387b003e4821c04ac3a67f64d3bf41620fb2db94 subject="CN=root@debixxx,O=linuxcontainers.org"
t=2021-09-26T23:49:47-0700 lvl=dbug msg="Matched trusted cert" fingerprint=1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5 subject="CN=root@debixx,O=linuxcontainers.org"
t=2021-09-26T23:49:47-0700 lvl=dbug msg=Handling ip=10.0.0.11:51920 method=POST protocol=cluster url=/internal/cluster/accept username=
t=2021-09-26T23:49:47-0700 lvl=dbug msg="\n\t{\n\t\t\"name\": \"debixx\",\n\t\t\"address\": \"10.0.0.11:8343\",\n\t\t\"schema\": 50,\n\t\t\"api\": 263,\n\t\t\"storage_pools\": [\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"size\": \"30GB\",\n\t\t\t\t\t\"source\": \"/var/snap/lxd/common/lxd/disks/steam.img\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"steam\",\n\t\t\t\t\"driver\": \"btrfs\",\n\t\t\t\t\"used_by\": null,\n\t\t\t\t\"status\": \"Created\",\n\t\t\t\t\"locations\": [\n\t\t\t\t\t\"none\"\n\t\t\t\t]\n\t\t\t}\n\t\t],\n\t\t\"networks\": [\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"ipv4.address\": \"10.233.90.1/24\",\n\t\t\t\t\t\"ipv4.nat\": \"true\",\n\t\t\t\t\t\"ipv6.address\": \"fd42:9627:a169:3307::1/64\",\n\t\t\t\t\t\"ipv6.nat\": \"true\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdbr0\",\n\t\t\t\t\"type\": \"bridge\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t},\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"ipv4.address\": \"10.221.12.1/24\",\n\t\t\t\t\t\"ipv4.nat\": \"true\",\n\t\t\t\t\t\"ipv6.address\": \"fd42:62b4:4f9c:24d2::1/64\",\n\t\t\t\t\t\"ipv6.nat\": \"true\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdvlan\",\n\t\t\t\t\"type\": \"bridge\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t},\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"parent\": \"eno1\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdvlan1\",\n\t\t\t\t\"type\": \"macvlan\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t}\n\t\t],\n\t\t\"architecture\": 2\n\t}"
t=2021-09-26T23:49:47-0700 lvl=dbug msg="Database error: &errors.errorString{s:\"No such object\"}"
t=2021-09-26T23:49:47-0700 lvl=warn msg="Failed to retrieve cluster member" err="No such object"
t=2021-09-26T23:49:49-0700 lvl=dbug msg="Database error: &errors.errorString{s:\"No such object\"}"
t=2021-09-26T23:49:49-0700 lvl=warn msg="Failed to retrieve cluster member" err="No such object"
t=2021-09-26T23:49:49-0700 lvl=dbug msg="Starting heartbeat round" address=10.0.0.150:8343 mode=normal
t=2021-09-26T23:49:49-0700 lvl=dbug msg="Heartbeat updating local raft members" members="[{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx} {NodeInfo:{ID:3 Address:10.0.0.11:8343 Role:spare} Name:} {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}]"
t=2021-09-26T23:49:49-0700 lvl=eror msg="Unaccounted raft node(s) not found in 'nodes' table for heartbeat: {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}"
t=2021-09-26T23:50:41-0700 lvl=dbug msg="Sending heartbeat request" address=10.0.0.100:8343
t=2021-09-26T23:50:41-0700 lvl=dbug msg="Successful heartbeat" address=10.0.0.100:8343
t=2021-09-26T23:50:41-0700 lvl=dbug msg="Completed heartbeat round" address=10.0.0.150:8343 duration=2.067227214s
t=2021-09-26T23:50:44-0700 lvl=dbug msg="Matched trusted cert" fingerprint=1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5 subject="CN=root@debixx,O=linuxcontainers.org"
t=2021-09-26T23:50:49-0700 lvl=dbug msg="Database error: &errors.errorString{s:\"No such object\"}"
t=2021-09-26T23:50:49-0700 lvl=warn msg="Failed to retrieve cluster member" err="No such object"
t=2021-09-26T23:50:49-0700 lvl=dbug msg="Starting heartbeat round" address=10.0.0.150:8343 mode=normal
t=2021-09-26T23:50:49-0700 lvl=dbug msg="Heartbeat updating local raft members" members="[{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx} {NodeInfo:{ID:3 Address:10.0.0.11:8343 Role:spare} Name:} {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}]"
t=2021-09-26T23:50:49-0700 lvl=eror msg="Unaccounted raft node(s) not found in 'nodes' table for heartbeat: {NodeInfo:{ID:5 Address:10.0.0.11:8443 Role:spare} Name:}"
Node 2 (10.0.0.100, debixxx)
t=2021-09-26T23:48:40-0700 lvl=dbug msg="Matched trusted cert" fingerprint=9d5535dd1a019de837603eb24506c3e8d845e34a6569b1fc8528e923fec6f4d9 subject="CN=root@debixps,O=linuxcontainers.org"
t=2021-09-26T23:48:40-0700 lvl=dbug msg="Replace current raft nodes with [{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx}]"
t=2021-09-26T23:49:40-0700 lvl=dbug msg="Matched trusted cert" fingerprint=9d5535dd1a019de837603eb24506c3e8d845e34a6569b1fc8528e923fec6f4d9 subject="CN=root@debixps,O=linuxcontainers.org"
t=2021-09-26T23:49:40-0700 lvl=dbug msg="Replace current raft nodes with [{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx}]"
t=2021-09-26T23:49:45-0700 lvl=dbug msg="Matched trusted cert" fingerprint=1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5 subject="CN=root@debixx,O=linuxcontainers.org"
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46174 method=GET protocol=cluster url=/1.0 username=
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46176 method=GET protocol=cluster url=/1.0/certificates/1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5 username=
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46178 method=GET protocol=cluster url=/1.0 username=
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46180 method=GET protocol=cluster url="/1.0/storage-pools?recursion=1" username=
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46182 method=GET protocol=cluster url="/1.0/projects?recursion=1" username=
t=2021-09-26T23:49:45-0700 lvl=dbug msg=Handling ip=10.0.0.11:46184 method=GET protocol=cluster url="/1.0/networks?project=default&recursion=1" username=
t=2021-09-26T23:49:46-0700 lvl=dbug msg="Matched trusted cert" fingerprint=1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5 subject="CN=root@debixx,O=linuxcontainers.org"
t=2021-09-26T23:49:46-0700 lvl=dbug msg=Handling ip=10.0.0.11:46186 method=POST protocol=cluster url=/internal/cluster/accept username=
t=2021-09-26T23:49:46-0700 lvl=dbug msg="\n\t{\n\t\t\"name\": \"debixx\",\n\t\t\"address\": \"10.0.0.11:8343\",\n\t\t\"schema\": 50,\n\t\t\"api\": 263,\n\t\t\"storage_pools\": [\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"size\": \"30GB\",\n\t\t\t\t\t\"source\": \"/var/snap/lxd/common/lxd/disks/steam.img\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"steam\",\n\t\t\t\t\"driver\": \"btrfs\",\n\t\t\t\t\"used_by\": null,\n\t\t\t\t\"status\": \"Created\",\n\t\t\t\t\"locations\": [\n\t\t\t\t\t\"none\"\n\t\t\t\t]\n\t\t\t}\n\t\t],\n\t\t\"networks\": [\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"ipv4.address\": \"10.233.90.1/24\",\n\t\t\t\t\t\"ipv4.nat\": \"true\",\n\t\t\t\t\t\"ipv6.address\": \"fd42:9627:a169:3307::1/64\",\n\t\t\t\t\t\"ipv6.nat\": \"true\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdbr0\",\n\t\t\t\t\"type\": \"bridge\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t},\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"ipv4.address\": \"10.221.12.1/24\",\n\t\t\t\t\t\"ipv4.nat\": \"true\",\n\t\t\t\t\t\"ipv6.address\": \"fd42:62b4:4f9c:24d2::1/64\",\n\t\t\t\t\t\"ipv6.nat\": \"true\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdvlan\",\n\t\t\t\t\"type\": \"bridge\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t},\n\t\t\t{\n\t\t\t\t\"config\": {\n\t\t\t\t\t\"parent\": \"eno1\"\n\t\t\t\t},\n\t\t\t\t\"description\": \"\",\n\t\t\t\t\"name\": \"lxdvlan1\",\n\t\t\t\t\"type\": \"macvlan\",\n\t\t\t\t\"Project\": \"default\"\n\t\t\t}\n\t\t],\n\t\t\"architecture\": 2\n\t}"
t=2021-09-26T23:49:46-0700 lvl=dbug msg="Redirect member accept request to 10.0.0.150:8343"
t=2021-09-26T23:49:47-0700 lvl=dbug msg=Handling ip=10.0.0.11:46190 method=GET protocol=cluster url="/1.0/certificates?recursion=1" username=
t=2021-09-26T23:50:41-0700 lvl=dbug msg="Matched trusted cert" fingerprint=9d5535dd1a019de837603eb24506c3e8d845e34a6569b1fc8528e923fec6f4d9 subject="CN=root@debixps,O=linuxcontainers.org"
t=2021-09-26T23:50:41-0700 lvl=dbug msg="Replace current raft nodes with [{NodeInfo:{ID:1 Address:10.0.0.150:8343 Role:voter} Name:debixps} {NodeInfo:{ID:2 Address:10.0.0.100:8343 Role:stand-by} Name:debixxx}]"
Node 3 (10.0.0.11, debixx, trying to join)
t=2021-09-26T23:48:43-0700 lvl=info msg="Kernel uid/gid map:"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - u 0 0 4294967295"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - g 0 0 4294967295"
t=2021-09-26T23:48:43-0700 lvl=info msg="Configured LXD uid/gid map:"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - u 0 1000000 1000000000"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - g 0 1000000 1000000000"
t=2021-09-26T23:48:43-0700 lvl=info msg="Kernel features:"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - closing multiple file descriptors efficiently: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - netnsid-based network retrieval: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - pidfds: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - uevent injection: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - seccomp listener: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - seccomp listener continue syscalls: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - seccomp listener add file descriptors: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - attach to namespaces via pidfds: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - safe native terminal allocation : yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - unprivileged file capabilities: yes"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - cgroup layout: cgroup2"
t=2021-09-26T23:48:43-0700 lvl=warn msg=" - Couldn't find the CGroup network priority controller, network priority will be ignored"
t=2021-09-26T23:48:43-0700 lvl=info msg=" - shiftfs support: disabled"
t=2021-09-26T23:48:43-0700 lvl=info msg="Initializing local database"
t=2021-09-26T23:48:44-0700 lvl=info msg="Set client certificate to server certificate" fingerprint=1b257dd342bc9ea6f9615dcddf853d3365168878ef9de1069d75b5070825b2b5
t=2021-09-26T23:48:44-0700 lvl=info msg="Starting database node" address=1 id=1 role=voter
t=2021-09-26T23:48:44-0700 lvl=info msg="Starting /dev/lxd handler:"
t=2021-09-26T23:48:44-0700 lvl=info msg=" - binding devlxd socket" socket=/var/snap/lxd/common/lxd/devlxd/sock
t=2021-09-26T23:48:44-0700 lvl=info msg="REST API daemon:"
t=2021-09-26T23:48:44-0700 lvl=info msg=" - binding Unix socket" inherited=true socket=/var/snap/lxd/common/lxd/unix.socket
t=2021-09-26T23:48:44-0700 lvl=info msg="Initializing global database"
t=2021-09-26T23:48:44-0700 lvl=info msg="Firewall loaded driver" driver=nftables
t=2021-09-26T23:48:44-0700 lvl=info msg="Initializing storage pools"
t=2021-09-26T23:48:44-0700 lvl=info msg="Initializing daemon storage mounts"
t=2021-09-26T23:48:44-0700 lvl=info msg="Loading daemon configuration"
t=2021-09-26T23:48:44-0700 lvl=info msg="Initializing networks"
t=2021-09-26T23:48:44-0700 lvl=info msg="Pruning leftover image files"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done pruning leftover image files"
t=2021-09-26T23:48:44-0700 lvl=info msg="Started seccomp handler" path=/var/snap/lxd/common/lxd/seccomp.socket
t=2021-09-26T23:48:44-0700 lvl=info msg="Pruning expired images"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done pruning expired images"
t=2021-09-26T23:48:44-0700 lvl=info msg="Pruning expired instance backups"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done pruning expired instance backups"
t=2021-09-26T23:48:44-0700 lvl=info msg="Updating images"
t=2021-09-26T23:48:44-0700 lvl=info msg="Updating instance types"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done updating images"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done updating instance types"
t=2021-09-26T23:48:44-0700 lvl=info msg="Pruning resolved warnings"
t=2021-09-26T23:48:44-0700 lvl=info msg="Expiring log files"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done pruning resolved warnings"
t=2021-09-26T23:48:44-0700 lvl=info msg="Done expiring log files"
t=2021-09-26T23:49:45-0700 lvl=info msg="Update network address"
t=2021-09-26T23:49:45-0700 lvl=info msg=" - binding TCP socket" socket=10.0.0.11:8343
t=2021-09-26T23:49:47-0700 lvl=info msg="Stop database gateway"
t=2021-09-26T23:49:47-0700 lvl=info msg="Starting database node" address=10.0.0.11:8343 id=11 role=voter
t=2021-09-26T23:49:47-0700 lvl=info msg="Joining dqlite raft cluster" address=10.0.0.11:8343 id=11 role=voter
t=2021-09-26T23:49:47-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.100:8343: no known leader"
t=2021-09-26T23:49:47-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.11:8343: no known leader"
t=2021-09-26T23:49:47-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.11:8443: dial: Failed to connect to HTTP endpoint: dial tcp 10.0.0.11:8443: connect: connection refused"
t=2021-09-26T23:49:47-0700 lvl=info msg="Adding node to cluster" address=10.0.0.11:8343 id=11 role=voter
t=2021-09-26T23:50:44-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.100:8343: no known leader"
t=2021-09-26T23:50:44-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.11:8343: no known leader"
t=2021-09-26T23:50:44-0700 lvl=warn msg="Dqlite: attempt 1: server 10.0.0.11:8443: dial: Failed to connect to HTTP endpoint: dial tcp 10.0.0.11:8443: connect: connection refused"
