Here’s all the data: ip a, ip r and lxc network show ovn-bridge-net:
lxclusternode01:
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:50:56:91:0a:76 brd ff:ff:ff:ff:ff:ff
inet 10.201.70.151/24 brd 10.201.70.255 scope global eth0
inet6 fe80::250:56ff:fe91:a76/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br1 state UP group default qlen 1000
link/ether 00:50:56:91:05:d5 brd ff:ff:ff:ff:ff:ff
inet6 fe80::250:56ff:fe91:5d5/64 scope link
4: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether ba:ed:51:a9:ef:5e brd ff:ff:ff:ff:ff:ff
6: br-int: <BROADCAST,MULTICAST> mtu 1442 qdisc noop state DOWN group default qlen 1000
link/ether 66:fb:a7:a0:80:e4 brd ff:ff:ff:ff:ff:ff
31: br1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.201.72.151/24 brd 10.201.72.255 scope global br1
32: genev_sys_6081: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 65000 qdisc noqueue master ovs-system state UNKNOWN group default qlen 1000
link/ether 52:63:92:62:73:12 brd ff:ff:ff:ff:ff:ff
inet6 fe80::5063:92ff:fe62:7312/64 scope link
33: lxdovn1b@lxdovn1a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master ovs-system state UP group default qlen 1000
link/ether 66:62:37:26:a3:f5 brd ff:ff:ff:ff:ff:ff
34: lxdovn1a@lxdovn1b: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br1 state UP group default qlen 1000
link/ether 9e:05:8a:4f:ca:aa brd ff:ff:ff:ff:ff:ff
35: lxdovn1: <BROADCAST,MULTICAST> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 02:c4:a0:2d:fa:48 brd ff:ff:ff:ff:ff:ff
39: veth6ea19323@if38: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1442 qdisc noqueue master ovs-system state UP group default qlen 1000
link/ether 82:cf:c8:e5:75:e3 brd ff:ff:ff:ff:ff:ff link-netnsid 0
default via 10.201.72.4 dev br1
10.30.16.0/24 via 10.201.70.1 dev eth0
10.40.16.0/24 via 10.201.70.1 dev eth0
10.49.24.0/24 via 10.201.70.1 dev eth0
10.196.43.178 via 10.201.70.1 dev eth0
10.201.16.0/24 via 10.201.70.1 dev eth0
10.201.70.0/24 dev eth0 proto kernel scope link src 10.201.70.151
10.201.72.0/24 dev br1 proto kernel scope link src 10.201.72.151
10.201.112.0/24 via 10.201.70.1 dev eth0
169.254.0.0/16 dev eth0 scope link metric 1002
169.254.0.0/16 dev br1 scope link metric 1031
bridge.mtu: "1442"
ipv4.address: 10.195.44.1/24
ipv4.nat: "true"
ipv6.address: fd42:df87:7c05:e876::1/64
ipv6.nat: "true"
network: UPLINK
volatile.network.ipv4.address: 10.201.72.230
type: ovn
- /1.0/instances/c02
- /1.0/instances/c10
managed: true
status: Created
locations:
- lxclusternode01
- lxclusternode02
- lxclusternode03
lxclusternode02
link/ether 00:50:56:91:67:4c brd ff:ff:ff:ff:ff:ff
inet 10.201.70.152/24 brd 10.201.70.255 scope global eth0
inet6 fe80::250:56ff:fe91:674c/64 scope link
link/ether 00:50:56:91:3c:ef brd ff:ff:ff:ff:ff:ff
inet6 fe80::250:56ff:fe91:3cef/64 scope link
4: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 92:e0:b0:61:bb:84 brd ff:ff:ff:ff:ff:ff
link/ether de:ba:11:fd:f8:80 brd ff:ff:ff:ff:ff:ff
29: br1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.201.72.152/24 brd 10.201.72.255 scope global br1
30: genev_sys_6081: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 65000 qdisc noqueue master ovs-system state UNKNOWN group default qlen 1000
link/ether 86:ce:e3:e3:fc:6e brd ff:ff:ff:ff:ff:ff
inet6 fe80::84ce:e3ff:fee3:fc6e/64 scope link
31: lxdovn1b@lxdovn1a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master ovs-system state UP group default qlen 1000
link/ether 56:86:20:ac:63:45 brd ff:ff:ff:ff:ff:ff
32: lxdovn1a@lxdovn1b: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br1 state UP group default qlen 1000
link/ether a6:f0:a6:68:88:a1 brd ff:ff:ff:ff:ff:ff
33: lxdovn1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6e:34:23:d8:fc:43 brd ff:ff:ff:ff:ff:ff
37: vethd37c7c56@if36: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1442 qdisc noqueue master ovs-system state UP group default qlen 1000
link/ether aa:97:6a:13:dd:14 brd ff:ff:ff:ff:ff:ff link-netnsid 0
10.201.70.0/24 dev eth0 proto kernel scope link src 10.201.70.152
10.201.72.0/24 dev br1 proto kernel scope link src 10.201.72.152
169.254.0.0/16 dev br1 scope link metric 1029
bridge.mtu: "1442"
ipv4.nat: "true"
ipv6.nat: "true"
network: UPLINK
type: ovn
managed: true
status: Created
locations:
- lxclusternode01
- lxclusternode02
- lxclusternode03
lxclusternode03
link/ether 00:50:56:91:b0:7d brd ff:ff:ff:ff:ff:ff
inet 10.201.70.153/24 brd 10.201.70.255 scope global eth0
inet6 fe80::250:56ff:fe91:b07d/64 scope link
link/ether 00:50:56:91:be:50 brd ff:ff:ff:ff:ff:ff
inet6 fe80::250:56ff:fe91:be50/64 scope link
link/ether a6:4b:f9:0c:8f:2e brd ff:ff:ff:ff:ff:ff
6: br-int: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether be:8b:b3:a8:dc:cc brd ff:ff:ff:ff:ff:ff
inet 10.201.72.153/24 brd 10.201.72.255 scope global br1
link/ether b6:05:ec:5b:e5:32 brd ff:ff:ff:ff:ff:ff
inet6 fe80::b405:ecff:fe5b:e532/64 scope link
link/ether ca:ac:2c:aa:4e:48 brd ff:ff:ff:ff:ff:ff
node32: lxdovn1a@lxdovn1b: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br1 state UP group default qlen 1000
link/ether d6:0b:95:d9:aa:06 brd ff:ff:ff:ff:ff:ff
link/ether 9e:57:c4:fe:c6:4d brd ff:ff:ff:ff:ff:ff
10.201.70.0/24 dev eth0 proto kernel scope link src 10.201.70.153
10.201.72.0/24 dev br1 proto kernel scope link src 10.201.72.153
bridge.mtu: "1442"
ipv4.nat: "true"
ipv6.nat: "true"
network: UPLINK
type: ovn
managed: true
status: Created
locations:
- lxclusternode01
- lxclusternode02
- lxclusternode03
These are my LXC networks and containers:
lxclusternode01 ~# lxc network ls
| NAME | TYPE | MANAGED | IPV4 | IPV6 | DESCRIPTION | USED BY | STATE |
| UPLINK | physical | YES | | | | 1 | CREATED |
| br1 | bridge | NO | | | | 1 | |
| br-int | bridge | NO | | | | 0 | |
| eth0 | physical | NO | | | | 0 | |
| eth1 | physical | NO | | | | 0 | |
| lxdovn1 | bridge | NO | | | | 0 | |
| ovn-bridge-net | ovn | YES | 10.195.44.1/24 | fd42:df87:7c05:e876::1/64 | | 2 | CREATED |
QA1 qa1lxcluster01 ~# lxc ls -c nS4tL
| NAME | SNAPSHOTS | IPV4 | TYPE | LOCATION |
| c02 | 0 | 10.195.44.3 (eth0) | CONTAINER | lxclusternode02 |
| c10 | 0 | 10.195.44.2 (eth0) | CONTAINER | lxclusternode01 |
