I have just screwed up by trying to install Ubuntu-core on a container rather than a VM (Clearly not enough coffee this morning!) . What has happened? Any recommendations for recover? I’d prefer not to have lost all my containers!.
Now LXD will not start, the journalctl log shows :
Apr 12 09:06:43 ash lxd.daemon[113042]: 1: fd: 6: name=systemd
Apr 12 09:06:43 ash lxd.daemon[113042]: 2: fd: 7: cpuset
Apr 12 09:06:43 ash lxd.daemon[113042]: 3: fd: 8: cpu,cpuacct
Apr 12 09:06:43 ash lxd.daemon[113042]: 4: fd: 9: rdma
Apr 12 09:06:43 ash lxd.daemon[113042]: 5: fd: 10: hugetlb
Apr 12 09:06:43 ash lxd.daemon[113042]: 6: fd: 11: freezer
Apr 12 09:06:43 ash lxd.daemon[113042]: 7: fd: 12: memory
Apr 12 09:06:43 ash lxd.daemon[113042]: 8: fd: 13: pids
Apr 12 09:06:43 ash lxd.daemon[113042]: 9: fd: 14: net_cls,net_prio
Apr 12 09:06:43 ash lxd.daemon[113042]: 10: fd: 15: perf_event
Apr 12 09:06:43 ash lxd.daemon[113042]: 11: fd: 16: devices
Apr 12 09:06:43 ash lxd.daemon[113042]: 12: fd: 17: blkio
Apr 12 09:06:43 ash lxd.daemon[113042]: Kernel supports pidfds
Apr 12 09:06:43 ash lxd.daemon[113042]: Kernel does not support swap accounting
Apr 12 09:06:43 ash lxd.daemon[113042]: api_extensions:
Apr 12 09:06:43 ash lxd.daemon[113042]: - cgroups
Apr 12 09:06:43 ash lxd.daemon[113042]: - sys_cpu_online
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_cpuinfo
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_diskstats
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_loadavg
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_meminfo
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_stat
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_swaps
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_uptime
Apr 12 09:06:43 ash lxd.daemon[113042]: - proc_slabinfo
Apr 12 09:06:43 ash lxd.daemon[113042]: - shared_pidns
Apr 12 09:06:43 ash lxd.daemon[113042]: - cpuview_daemon
Apr 12 09:06:43 ash lxd.daemon[113042]: - loadavg_daemon
Apr 12 09:06:43 ash lxd.daemon[113042]: - pidfds
Apr 12 09:06:44 ash lxd.daemon[112906]: => Starting LXD
Apr 12 09:06:44 ash lxd.daemon[113053]: time=“2024-04-12T09:06:44Z” level=warning msg=" - Couldn’t find the CGroup blkio.weight, disk priority will be ignored"
Apr 12 09:06:44 ash lxd.daemon[113053]: time=“2024-04-12T09:06:44Z” level=warning msg=" - Couldn’t find the CGroup memory swap accounting, swap limits will be ignored"
Apr 12 09:06:45 ash lxd.daemon[113053]: time=“2024-04-12T09:06:45Z” level=error msg=“Failed loading storage pool” err=“Required tool ‘zpool’ is missing” pool=default
Apr 12 09:06:45 ash lxd.daemon[113053]: time=“2024-04-12T09:06:45Z” level=error msg=“Failed to start the daemon” err="Failed applying patch "storage_move_custom_iso_block_volumes_v2": Failed loading pool >
Apr 12 09:06:45 ash lxd.daemon[113053]: Error: Failed applying patch “storage_move_custom_iso_block_volumes_v2”: Failed loading pool “default”: Required tool ‘zpool’ is missing
Apr 12 09:06:46 ash lxd.daemon[112906]: Killed
Apr 12 09:06:46 ash lxd.daemon[112906]: => LXD failed to start
Apr 12 09:06:46 ash systemd[1]: snap.lxd.daemon.service: Main process exited, code=exited, status=1/FAILURE
Apr 12 09:06:46 ash systemd[1]: snap.lxd.daemon.service: Failed with result ‘exit-code’.
Apr 12 09:06:46 ash systemd[1]: snap.lxd.daemon.service: Scheduled restart job, restart counter is at 394.
Apr 12 09:06:46 ash systemd[1]: Stopped Service for snap application lxd.daemon.
Apr 12 09:06:46 ash systemd[1]: Started Service for snap application lxd.daemon.
Apr 12 09:06:46 ash lxd.daemon[113138]: => Preparing the system (28155)
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Loading snap configuration
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Setting up mntns symlink (mnt:[4026533642])
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Setting up kmod wrapper
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Preparing /boot
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Preparing a clean copy of /run
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Preparing /run/bin
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Preparing a clean copy of /etc
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Preparing a clean copy of /usr/share/misc
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Setting up ceph configuration
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Setting up LVM configuration
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Setting up OVN configuration
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Rotating logs
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Unsupported ZFS version (0.8)
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Escaping the systemd cgroups
Apr 12 09:06:46 ash lxd.daemon[113138]: ====> Detected cgroup V1
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Escaping the systemd process resource limits
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Enabling LXD UI
Apr 12 09:06:46 ash lxd.daemon[113138]: ==> Exposing LXD documentation
Apr 12 09:06:46 ash lxd.daemon[113042]: Running destructor lxcfs_exit
Apr 12 09:06:46 ash lxd.daemon[113138]: => Starting LXCFS
Apr 12 09:06:46 ash lxd.daemon[113273]: Starting LXCFS at lxcfs
Apr 12 09:06:46 ash lxd.daemon[113273]: Running constructor lxcfs_init to reload liblxcfs
Apr 12 09:06:46 ash lxd.daemon[113273]: mount namespace: 4
Apr 12 09:06:46 ash lxd.daemon[113273]: hierarchies:
Apr 12 09:06:46 ash lxd.daemon[113273]: 0: fd: 5:
Apr 12 09:06:46 ash lxd.daemon[113273]: 1: fd: 6: name=systemd
Apr 12 09:06:46 ash lxd.daemon[113273]: 2: fd: 7: cpuset
Apr 12 09:06:46 ash lxd.daemon[113273]: 3: fd: 8: cpu,cpuacct
Apr 12 09:06:46 ash lxd.daemon[113273]: 4: fd: 9: rdma
Apr 12 09:06:46 ash lxd.daemon[113273]: 5: fd: 10: hugetlb
Apr 12 09:06:46 ash lxd.daemon[113273]: 6: fd: 11: freezer
Apr 12 09:06:46 ash lxd.daemon[113273]: 7: fd: 12: memory
Apr 12 09:06:46 ash lxd.daemon[113273]: 8: fd: 13: pids
Apr 12 09:06:46 ash lxd.daemon[113273]: 9: fd: 14: net_cls,net_prio
Apr 12 09:06:46 ash lxd.daemon[113273]: 10: fd: 15: perf_event
Apr 12 09:06:46 ash lxd.daemon[113273]: 11: fd: 16: devices
Apr 12 09:06:46 ash lxd.daemon[113273]: 12: fd: 17: blkio
Apr 12 09:06:46 ash lxd.daemon[113273]: Kernel supports pidfds
Apr 12 09:06:46 ash lxd.daemon[113273]: Kernel does not support swap accounting
Apr 12 09:06:46 ash lxd.daemon[113273]: api_extensions:
Apr 12 09:06:46 ash lxd.daemon[113273]: - cgroups
Apr 12 09:06:46 ash lxd.daemon[113273]: - sys_cpu_online
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_cpuinfo
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_diskstats
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_loadavg
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_meminfo
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_stat
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_swaps
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_uptime
Apr 12 09:06:46 ash lxd.daemon[113273]: - proc_slabinfo
Apr 12 09:06:46 ash lxd.daemon[113273]: - shared_pidns
Apr 12 09:06:46 ash lxd.daemon[113273]: - cpuview_daemon
Apr 12 09:06:46 ash lxd.daemon[113273]: - loadavg_daemon
Apr 12 09:06:46 ash lxd.daemon[113273]: - pidfds
Apr 12 09:06:47 ash lxd.daemon[113138]: => Starting LXD
Apr 12 09:06:47 ash lxd.daemon[113284]: time=“2024-04-12T09:06:47Z” level=warning msg=" - Couldn’t find the CGroup blkio.weight, disk priority will be ignored"
Apr 12 09:06:47 ash lxd.daemon[113284]: time=“2024-04-12T09:06:47Z” level=warning msg=" - Couldn’t find the CGroup memory swap accounting, swap limits will be ignored"
