Howdy,
I would like to set up a Debian-based VM in Incus, install Incus within it, and use that instance as a virtual server running LXC containers. I have two ethernet ports on my machine and a wireless card, all of which I would like for the VM to ‘own.’ The machine runs 64-bit MX Linux 23.1 with KDE.
I am using this tutorial from @trevor, hoping to set up the ‘bridge network adapter’ as the parent of the physical eth0, but let the VM have the two other, actual devices. I expect to pass the other two into one of the nested LXC containers, running something like OpenWRT, as physical nictypes, as well.
I created a project, a storage volume, a profile, a network, and an instance; respectively, anvil, anvil, anvil, anvilbr0, and kixikur. Here is an excerpt from that profile:
nictype: bridged
parent: anvilbr0
eth1:
nictype: physical
parent: eth1
pool: anvil
wlan0:
nictype: physical
parent: wlan0
But, to me, the networks in the instance don’t look right.
In the instance, it looks like
lo changes host interface every second or so, and where are the rest of the interfaces? From inside the instance:
root@kixikur:~# ip addr
inet6 ::1/128 scope host noprefixroute
2: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:16:3e:aa:59:fc brd ff:ff:ff:ff:ff:ff
inet 10.31.188.71/24 metric 1024 brd 10.31.188.255 scope global dynamic enp5s0
valid_lft 3515sec preferred_lft 3515sec
inet6 fd42:a2c:5926:cd1e:216:3eff:feaa:59fc/64 scope global mngtmpaddr noprefixroute
inet6 fe80::216:3eff:feaa:59fc/64 scope link
3: enp6s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 3c:52:82:5d:13:44 brd ff:ff:ff:ff:ff:ff
From outside the instance:
$ ip addr
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether a0:36:9f:43:ac:f3 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.10/24 brd 192.168.0.255 scope global dynamic noprefixroute eth0
valid_lft 3061sec preferred_lft 3061sec
inet6 fe80::6f64:ffa3:5d7f:d1da/64 scope link noprefixroute
5: anvilbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 00:16:3e:b1:4a:af brd ff:ff:ff:ff:ff:ff
inet 10.31.188.1/24 scope global anvilbr0
inet6 fd42:a2c:5926:cd1e::1/64 scope global
inet6 fe80::216:3eff:feb1:4aaf/64 scope link
6: incusbr-1001: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:ff:ed:0b brd ff:ff:ff:ff:ff:ff
inet 10.148.13.1/24 scope global incusbr-1001
inet6 fd42:d3c5:22b0:6cd4::1/64 scope global
7: incusbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 00:16:3e:1a:c0:0e brd ff:ff:ff:ff:ff:ff
inet 10.58.164.1/24 scope global incusbr0
inet6 fd42:acda:9d30:547::1/64 scope global
10: tapf3d391dc: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master anvilbr0 state UP group default qlen 1000
link/ether c2:77:60:c4:c1:0a brd ff:ff:ff:ff:ff:ff
If I understood the tutorial, then the instance should only have one interface, corresponding to the anvilbr0, but it has two enpXsX instead. And, the host still uses eth0, yet now has the tap interface. I’m not familiar with tap interfaces, or probably most networking concepts. Having read documentation and blogs, and watched presentations and tutorials, I thought this would make more sense to me than it does. I appreciate your help.
Best,
UpsetMOSFET
EDIT: I should also mention that apt update doesn’t work in the instance. It looks like that’s because it has no internet; every repository only loads to zero percent. Something about networks.
EDIT2: I did say, “something like OpenWRT.” I won’t be using OpenWRT, itself, as @stgraber indicated in this post that it would be bad for specifically what I want to do. I’m hoping DietPi with Pihole+Unbound will do the trick for me, maybe with Shorewall. Open to suggestions there, too.
Yeah, debugging with @mcondarelli has showed that OpenWRT does actively rename interfaces both on startup and shutdown, so that’s definitely a bit of a problem.
EDIT3: It occurs to me that this may require the user running Incus to have superuser permission, not just to be a member of incus-admin. What effect does this have?
