Hello dear colleagues,
After exporting a container to a tarball, I would like to change some of its metadata before I import it on another LXD host. Is there a recommended way of doing it? I assume the metadata is stored in configuration files in tarball, but there are too many files inside for me find them myself.
The concrete case is that a container exported with LXD 5 cannot be imported to LXD 4 because of the Unknown configuration key: volatile.uuid.generation
. (See forum post)
My hope is that I will be able to remove this key from the exported container’s configuration tarball and complete the import on LXD 4.
I was unable to find documentation on the tarball’s structure, can anybody help?
