Help with preseed
Hi
I get an error when applying my preseed, so there is probably something wrong there, but I just don’t see it (missing experience here). This is the preseed:
networks:
- config:
    ipv4.address: auto
    ipv4.nat: 'true'
    ipv6.address: auto
    ipv6.nat: 'true'
  description: Internal/NATted bridge
  type: bridge
- config:
    security:
      secureboot: 'false'
  description: Basis config
      pool: default
- description: Internal Instances
      network: internalbr0
- description: Server Instances (VLAN 50)
      nictype: bridged
      parent: vmbr0
      vlan: '50'
- description: Test instances (VLAN 200)
      nictype: bridged
      parent: vmbr0
      vlan: '200'
- description: Appliances (VLAN 70)
     nictype: bridged
      parent: vmbr0
      vlan: '70'
storage_pools:
- config:
    source: zroot/incus
  driver: zfs
And this is the error message:
Error: Failed to parse the preseed: type map[interface {}]interface {} is not supported in *api.ConfigMap
Anybody can tell me, what I did wrong?
Thanks.
P.S.: Think, I probably found it by replicating the config in the UI and looking at the generated yaml: the “name: eth0” entry is redundant, it seems. I will now remove that and see, if it works.
Should be:
- config:
    security.secureboot: "false"
Thanks for spotting this. :slightly_smiling_face: This was generated by nixos. Apparently I need to put the key name in quotes for it to not separate it into two lines.
