i have a container which is running docker and it created a docker0 bridge network, how do i hide this network from the host? Currently it is visible and pingable from the host. Is it possible?
Please can you provide an example of what you mean?
I want to hide this docker0 interface from the host, currently i can ping 10.30.10.1, but i want that only eth0 to be visible
But that isn’t visible in the host, its only visible when you run a command inside the container (like ip a in this case) or look at the container’s network info from LXD.
Running ip a on the host won’t show docker0.
But i can ping the 10.30.10.1 from the host
this is what confuses me
Oh right so you mean reachable rather than visible.
Please show ip a and ip r on the host.
So from the host 10.30.10.1 is just the LXD managed bridge, not docker0 inside the container.
Although that sort of setup (having docker on an overlapping /24 of your container’s subnet) is going to get very confusing
I may should use other subnets rather than 10.30.* .* for everything xD
