To import as a container, it needs to be dealing with a mount filesystem or set of filesystems so it can transfer individual files. If all you have is a compressed full disk image like you have here, this only can be imported as a VM.
if i understand correclty, i could import it as a vm, run the tool inside to migrate it to a container?
Possibly. Home Assistant runs a whole bunch of containers, so itâs not a very good candidate for running nicely as a container itself.
thank you very much for your time
Hi all, Iâm actually using the 4th option, ie running HA OCI Container directly in Incus:
This works but I need to run Addon OCI Containers alongside the HA Container,
in lieu of real Addons.
The normal way of doing this requires network_mode: host and then it all just works.
But I cannot for the life of me figure out how to do that for OCI.
Without this, getting these pseudo âadd-onsâ working, becomes a nightmare.
Host networking works for LXC but getting it to work for OCI eludes me.
Any insights would be appreciated :o) Here is my current config:
admin@zero:~$ incus config show --expanded homeassistant
boot.autorestart: "true"
boot.autostart: "true"
environment.HOME: /root
environment.LANG: C.UTF-8
environment.PATH: /usr/local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
environment.S6_BEHAVIOUR_IF_STAGE2_FAILS: "2"
environment.S6_CMD_WAIT_FOR_SERVICES: "1"
environment.S6_CMD_WAIT_FOR_SERVICES_MAXTIME: "0"
environment.S6_SERVICES_GRACETIME: "240000"
environment.S6_SERVICES_READYTIME: "50"
environment.TERM: xterm
environment.TZ: America/Vancouver
environment.UV_EXTRA_INDEX_URL: https://wheels.home-assistant.io/musllinux-index/
environment.UV_NO_CACHE: "true"
environment.UV_SYSTEM_PYTHON: "true"
image.architecture: x86_64
image.description: ghcr.io/home-assistant/home-assistant (OCI)
image.id: home-assistant/home-assistant:stable
image.type: oci
oci.cwd: /config
oci.entrypoint: /init
oci.gid: "0"
oci.uid: "0"
security.privileged: "true"
volatile.base_image: 77723dbee4ea658ff1df2d16c40242be5a171eb55785eba11df1f4d143850fef
volatile.cloud-init.instance-id: b5bd0a0e-8071-4617-a5a8-f3ee7da1006f
volatile.container.oci: "true"
volatile.eth0.host_name: veth2377e034
volatile.eth0.hwaddr: 10:66:6a:c0:94:a9
volatile.idmap.base: "0"
volatile.idmap.current: '[]'
volatile.uuid: d1f3db6c-7301-462b-b4b3-4b1c67b40974
volatile.uuid.generation: d1f3db6c-7301-462b-b4b3-4b1c67b40974
dbus:
path: /run/dbus
readonly: "true"
source: /run/dbus
nictype: bridged
parent: br1
ha-config:
path: /config
pool: default
source: ha-config
pool: default
profiles: []
I have tried
incus config set ha1 raw.lxc="lxc.net.0.type=none"
But it fails with error:
Invalid config: Only interface-specific ipv4/ipv6 lxc.net. keys are allowed
Apparently OCI runs within LXC so how can I get this to pass the host network stack through from LXC to OCI instead of using a bridge or macvlan which would break integration between OCI containers?
Thanks and agreed; The better way might be to allow sharing of the network stack belonging to a SPECIFIED interface or bridge among several OCI containers, instead of the entire host stack. I can imagine that would be a LOT of work if even possible (clone the host namespace?), but it would be superior to anything else currently available out there.
But thanks for the fixup, I will move Home Assistant into Incus instead of using Docker as soon as your raw.lxc fix is released to production.
Perhaps the ability to create and share among specific OCI containers,
a new âprivateâ instance of âlocalhostâ interface,
alongside a specific (named) interface that already exists in the host,
might satisfy most use cases which would normally require âânetwork=hostâ?
Call me crazy, but I think within 2 years, AI will solve this problem without having to iteratively figure it out the hard way. Free code!
Full solution to run Home Assistant OCI container in Incus using Host Networking:
admin@main:~$ incus init ghcr:home-assistant/home-assistant:stable homeassistant --no-profiles --storage default -c raw.lxc=âlxc.net.0.type=noneâ -c security.privileged=true -c boot.autostart=true -c boot.autorestart=true -c environment.TZ=America/Vancouver
Why did you need security.privileged=true?
Itâs very very rare that itâs truly needed and it makes things quite badly unsafe.
The main exception (at least in all the environments Iâm dealing with) is for image building where the container needs to be able to directly mess with disk images, create partitions and mount arbitrary filesystems. But those Iâm generally moving to VMs these days to avoid security.privileged.
The official Home Assistant instructions for Docker recommend the ââprivilegedâ flag so I replicated this, but yeah âŠIâll try to get rid of it once I have matter-server and hass-otbr-docker all up and running alongside. Would be nice to also get rid of host networking, but Iâm no guru so for me itâs one step at a time. Thanks for bringing this up and thanks for making it possible to run Docker containers alongside VMâs and LXC in Incus. What a great project! I think the TrueNAS community is goiing to LOVE this, and Iâm going to try TrueNAS this winter too!
Iâm thinking about running homeassistant this way as well. What are the implications of âraw.lxc=âlxc.net.0.type=noneâ ?
I guess I could use this with other simple app containers and avoid software bridge and associated cpu overhead?
I assume there are some security downsides but what else?
FWIW I had to also use host networking for the matter-server OCI container but raw.lxc=âlxc.apparmor.profile=unconfinedâ is wrecking network connectivigy (have not looked into why yet). Mosqitto works fine over localhost. Thread border router is next on my ToDo list. If I get everything working, and then working without these security holes, then Iâll post it on the HA forum. Iâm reasonably confident that Iâll get there if I donât die of old age first.
I tried it and couldnât get it work.
I could get it running as a container a week ago, but it wonât launch the needed docker images because of rauc not working under Incus, it requires the partitions for the immutable system
