It should change to whatever the owner of the source path is, so if /home/gabriel/myapp is owned by root:root on the host, it would show up at root:root in the container.
But on top of that, you have to consider uid/gid maps that can also shift those bits around a bit, at least if your container is unprivileged.
let me try to explain another way. The mounted device ownership is ok. The issue is on the parent folder. For instance, let’s say I’m adding the following device:
lxc config device add test-container app disk source=/home/gabriel/a/b/c/d path=/home/ubuntu/a/b/c/d
d/ folder ownership is ok. (nobody:nogroup)
But ubuntu/, a/, b/ and c/ are now owned by root:root, when it would be ubuntu:ubuntu.
Actually, I don’t know about a/, b/ and c/. But ubuntu/ definitely should be owned by ubuntu:ubuntu, right?
Ah, I see, and did /home/ubuntu already exist back when you first added that disk entry?
If not, then LXD would have been the one creating it so that the mountpoint exists and as that’s done by a root process in the container, root:root is what you’re getting.
