In order to faciliate programming a TM4C123 development board, from a lxd container, I have done the following:
My configuration:
tm4c:
productid: 00fd
type: usb
vendorid: 1cbe
In my host computers /etc/udev/rules.d/71-lxd-ti.rules
ATTRS{idVendor}==“1cbe”, ATTRS{idProduct}==“00fd”, GROUP=“users”, MODE=“0666”
If the development board is plugged in before the container starts, the above configuration works and lm4flash program can access the development board.
Found ICDI device with serial: 0E20E60E
ICDI version: 9270
But however, if you unplug and plug back the dev board, or reset it:
Unable to open USB device: LIBUSB_ERROR_ACCESS
Unable to find any ICDI devices
It seems that naturally, the device is registered when the container starts, and then accessible tru the container. In hardware development, there is a lot of plugging and unplugging and swapping boards, etc, so I kind of need it.
Is there any way I can go around this issue?
Also, when we define permissions of a device in the host computer’s udev/rules.d - and lxc accesses this device, which uid does it access as? Usually this device has 660 permissions, and the user has to be a member of dialout and plugdev. But I understand lxd will be accessing this device, so it is lxd’s uid?
would it help to list the rules file in the containers /etc/udev/rules.d ?
Best regards,
C.
