How would I import a pool to a new LXD installation without loosing the container in the pool.
With pool I mean storage, in the table under column “NAME” and in this case called pool.
How can I change the default pool for new containers to use?
How can I move containers over to another storage source?
| default | | dir | /var/snap/lxd/common/lxd/storage-pools/default | 1 |
| pool | | btrfs | /dev/sda1 | 0 |
