Hm. I have to idea. Any suggestions?
Can you show your updated:
- incus network show NAME
- incus config show --expanded NAME
- incus query /internal/debug/bgp (from the machine currently running the instance)
| debug | RUNNING | 10.35.28.245 (enp5s0) | | VIRTUAL-MACHINE | 0 | mini2 |
vm in mini2 server
ansible@mini2 ~> sudo incus network show incusbr0
bgp.peers.debug.address: 192.168.20.51
bgp.peers.debug.asn: "64512"
bgp.peers.mikrotik.address: 192.168.20.1
bgp.peers.mikrotik.asn: "65540"
ipv4.address: 10.35.28.1/24
ipv4.nat: "false"
ipv6.address: none
type: bridge
- /1.0/instances/debug
- /1.0/profiles/default
- /1.0/profiles/packer
managed: true
status: Created
locations:
- mini1
- mini3
- worker1
- mini2
- mini5
- mini4
- lb
project: default
ansible@mini2 ~> sudo incus config show --expanded debug
cluster.evacuate: auto
image.architecture: amd64
image.description: Ubuntu noble amd64 (cloud) (20251126_07:42)
image.name: ubuntu-noble-amd64-cloud-20251126_07:42
image.os: ubuntu
image.release: noble
image.serial: "20251126_07:42"
image.variant: cloud
limits.cpu: "2"
limits.memory: 2GiB
migration.stateful: "true"
volatile.base_image: 8d3e6ff9770f2d2da831982c06967600e963ca0eb58353b2bf1f6c3b8b736b24
volatile.cloud-init.instance-id: 517f6db5-b2df-4f1b-a90b-5f5a092822c2
volatile.eth0.host_name: tap1367dc15
volatile.eth0.hwaddr: 10:66:6a:25:38:bb
volatile.uuid: eefc17b4-cd07-4feb-942b-79c23c664df2
volatile.uuid.generation: eefc17b4-cd07-4feb-942b-79c23c664df2
volatile.vm.definition: pc-q35-10.1
volatile.vm.rtc_adjustment: "-1"
volatile.vm.rtc_offset: "0"
volatile.vsock_id: "1410789558"
ipv4.routes.external: 10.35.28.218/32
network: incusbr0
pool: local
ansible@mini2 ~> sudo incus query /internal/debug/bgp
"peers": [
"address": "192.168.20.1",
"asn": 65540,
"count": 1,
"holdtime": 0,
"password": ""
"address": "192.168.20.51",
"asn": 64512,
"count": 1,
"holdtime": 0,
"password": ""
"prefixes": [
"nexthop": "0.0.0.0",
"owner": "network_2",
"prefix": "10.35.28.0/24"
"owner": "instance_19_eth0",
"prefix": "10.35.28.218/32"
"server": {
"address": "0.0.0.0:179",
"asn": 65536,
"router_id": "192.168.20.22",
"running": true
/32 prefix exists.
And last problem - how to automate it?
Okay, so thatâs looking good. By the way, not that the
ipv4.routes.externaldoesnât match the instanceâs address so that is likely broken right now.It should be pretty easy to script it, effectively:
Get the instance list
Check if the instance NIC already has
ipv4.addressandipv4.routes.externalsetIf not, get the instance current IPv4 address and put it in both config keys
We canât do too much more than that automatically in Incus as weâre not in charge of the instanceâs IP address, itâs automatically allocated by dnsmasq and weâre not getting notified or anything when the lease is made, or changed.
If youâre using tooling like Terraform/OpenTofu to create the instances, you could have that set both config keys for you as part of creation.
