Currently having a tough time trying to enable audio output on my windows vm. Is there an easy way to this please?
LXD doesn’t currently have a virtual sound card.
You may be able to add one by using raw.qemu
to directly pass qemu options.
Though for Windows, if using a version that has it, I find that connecting over RDP which supports proper sound redirection tends to give the better experience.
Grateful! But is there a step by step guide to this please?
