| INSEARCH | RUNNING | 10.62.161.189 (eth0) | fd42:8c3e:8a10:f42c:216:3eff:feca:1ba9 (eth0) | CONTAINER | 0 |
| hip-cat | RUNNING | 10.62.161.62 (eth0) | fd42:8c3e:8a10:f42c:216:3eff:fe31:4ea6 (eth0) | CONTAINER | 0 |
root@Q1:/home/ic2000# wget 10.62.161.189
–2023-12-21 14:41:52-- http://10.62.161.189/
Connecting to 10.62.161.189:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 612 [text/html]
Saving to: ‘index.html.3’
index.html.3 100%[==========>] 612 --.-KB/s in 0s
2023-12-21 14:41:52 (50.5 MB/s) - ‘index.html.3’ saved [612/612]
Does Incus support a cluster? Having issues because every server on different subnet and they cant see each other’s containers.
Also lxd-to-incus
=> Looking for source server
==> Detected: snap package
=> Looking for target server
==> Detected: systemd
=> Connecting to source server
Error: Failed to connect to the source: Get “http://unix.socket/1.0”: dial unix /var/snap/lxd/common/lxd/unix.socket: connect: connection refused
root@Q2:/home/ic2000# incus cluster list
Error: Server isn’t part of a cluster
How can fix my confused server or may be I am confused…
