Hello there,
I am pretty new to LXC and am wondering how assigning an IP addresses to a container’s veth
interface works? So, here is my setup:
I run a Debian bookworm container on a Debian bookworm host. To avoid collisions in my network, I had to modify /etc/default/lxc-net
USE_LXC_BRIDGE="true"
LXC_BRIDGE="lxcbr0"
LXC_ADDR="192.168.0.1"
LXC_NETMASK="255.255.255.0"
LXC_NETWORK="192.168.0.0/24"
LXC_DHCP_RANGE="192.168.0.2,192.168.0.254"
LXC_DHCP_MAX="253"
LXC_DHCP_CONFILE=""
And consequently added the following lines to my containers config file:
lxc.net.0.name = eth0
lxc.net.0.link = lxcbr0
lxc.net.0.flags = up
lxc.net.0.ipv4.address = 192.168.0.2/24
lxc.net.0.ipv4.gateway = 192.168.0.1
However, when I started the container, no IP address was assigned to the eth0
interface:
inet6 ::1/128 scope host
2: eth0@if22: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 22:cf:97:4a:a6:b0 brd ff:ff:ff:ff:ff:ff link-netnsid 0
inet6 fe80::18ff:bff:fe99:88dc/64 scope link
I then configured nftables on the host to allow DHCP and subsequently the container got a random IP assigned, but not the IP I had configured (and intended):
2: eth0@if21: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.0.80/24 brd 192.168.0.255 scope global dynamic eth0
valid_lft 2582sec preferred_lft 2582sec
inet6 fe80::a0cb:5cff:fe72:15e5/64 scope link
So my question is: How is it supposed to work that the container gets the IP assigned that was defined in the container’s config file?
(Of course I could set the static IP by editing the container’s /etc/network/interfaces
, but I am interested in how it is supposed to work?!).
EDIT:
Uhhh, that’s interesting: When I disallow DHCP via nftables and run lxc-ls -f
right after starting the container, it seems to get the correct - static - IP address:
NAME STATE AUTOSTART GROUPS IPV4 IPV6 UNPRIVILEGED
mycontainer RUNNING 0 - 192.168.0.2 - true
But when I run lxc-ls -f
a few seconds later, the IPv4 address has vanished:
mycontainer RUNNING 0 - - - true
It seems something inside the container is somehow fighting the static IP address?
