Hi. I have nat enabled on lxdbr0 default network and its working ok. However, I would have expected to find some masquerading among the iptables rules that lxd creates automatically, but couldn’t find any. (LXD runing on debian buster with iptables set to legacy)
I would appreciate it if someone can comment on how Nat is implemented. I would like to understand it and be able to make some custom configurations.
Thanks.
Can you show lxc info | grep firewall:
LXD uses nft directly when available and when no rules are present in xtables at the time it starts. I suspect that on your system, it is indeed using nft.
Hi Stéphane thanks for your reply.
Lxc info shows the following:
% lxc info | grep -i firewall:
firewall: xtables
When I installed LXD I switched to iptables-legacy because LXD was using xtables due to kernel version < 5 (Host runs Debian 10 with kernel 4.19).
I checked and nft ruleset is emtpy:
% sudo nft list ruleset
table ip filter {
chain INPUT {
type filter hook input priority 0; policy accept;
chain FORWARD {
type filter hook forward priority 0; policy accept;
chain OUTPUT {
type filter hook output priority 0; policy accept;
Output from Iptables and lxc network show is the following:
% sudo iptables -S | grep -i lxd
-A INPUT -i lxdbr0 -p tcp -m tcp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A INPUT -i lxdbr0 -p udp -m udp --dport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -o lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A FORWARD -i lxdbr0 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p tcp -m tcp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 53 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
-A OUTPUT -o lxdbr0 -p udp -m udp --sport 67 -m comment --comment "generated for LXD network lxdbr0" -j ACCEPT
% lxc network show lxdbr0
ipv4.address: 10.140.62.1/24
ipv4.nat: "true"
ipv6.address: fd42:1a6b:ffad:29df::1/64
ipv6.nat: "true"
type: bridge
- /1.0/instances/debianc1
- /1.0/instances/ubuntuc1
- /1.0/profiles/default
managed: true
status: Created
locations:
- none
Thanks.
Sorry after reading my own answer i realized that I was not listing the nat table.
Now it is clear:
% sudo iptables -S -t nat | grep -i lxd
-A POSTROUTING -s 10.140.62.0/24 ! -d 10.140.62.0/24 -m comment --comment "generated for LXD network lxdbr0" -j MASQUERADE
Thanks
