We have non-obvious behavior when enable security.idmap.isolated
Our setup with disabled security.idmap.isolated, all containers use default profile and have settings:
lxc config show ct1 | grep volatile.idmap
ct1
volatile.idmap.base: "0"
volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1148576,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1148576,"Nsid":0,"Maprange":65536}]'
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1148576,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":1148576,"Nsid":0,"Maprange":65536}]'
lxc config show ct2 | grep volatile.idmap
ct2
System settings from subuid and subgid files
cat /etc/subuid | grep "lxd\|root"
lxd:1148576:65536
root:1148576:65536
cat /etc/subgid | grep "lxd\|root"
lxd:1148576:65536
root:1148576:65536
here we see that all containers use default UID allocation for containers. Root user in container maps to system UID 1148576.
Then we change subuid and subgid files and set maximum ID for root and lxd users to 2000000:
lxd:1148576:2000000
root:1148576:2000000
lxd:1148576:2000000
Then we restarted LXD service for the changes to take effect. And enable security.idmap.isolated in default profile
lxc profile set security.idmap.isolated true
all containers change their volatile.idmap.base to new values 65536, 131072 and so on, with step of 65536.
ct1
volatile.idmap.base: "65536"
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":65536,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":65536,"Nsid":0,"Maprange":65536}]'
ct2
volatile.idmap.base: "131072"
volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":131072,"Nsid":0,"Maprange":65536},{"Isuid":false,"Isgid":true,"Hostid":131072,"Nsid":0,"Maprange":65536}]'
After restart this containers not started with error:
newuidmap failed to write mapping "newuidmap: uid range [0-65536) -> [589824-655360) not allowed"
And here are pool of questions:
- Is the are any detailed manual about how security.idmap.isolated works and sets?
- Why volatile.idmap.base starts from 65536 if minimal ID for lxd or root subuid is 1148576?
- Can we set minimal ID from which LXD will start count to 1148576?
- Can we change minimal ID step, not use default 65536?
- Can we set predictable and static UID for container which not changed during container life cycle?
